Question for the 335 experts...
Old Nov 10, 2009 | 09:16 PM
StuartsPNB's Avatar
StuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to behold
Hey guys,
I have buddy who is looking for a "piggy back" style chip for his 2007 335i coupe.
What do you guys suggest? He just needs a wake up chip no flashing...
Any suggestions?
What about this?
http://www.amazon.com/Turbo-Tuner-13...7912757&sr=8-1
Old Nov 10, 2009 | 09:53 PM
kailuaboy's Avatar
kailuaboy has a spectacular aura aboutkailuaboy has a spectacular aura about
I know there are some good options out there. if he would like to keep the warranty i would look at dinan. they are fairly expensive but if or when something breaks they will fix it. aside from that im not too sure whats out there. there are some pretty good bmw forums that might be of help.
Old Nov 10, 2009 | 11:41 PM
aus's Avatar
aus
aus has much to be proud ofaus has much to be proud ofaus has much to be proud ofaus has much to be proud ofaus has much to be proud ofaus has much to be proud ofaus has much to be proud ofaus has much to be proud ofaus has much to be proud of
That's a common misperception. What happens when turbo goes bad? BMW will blame Dinan and Dinan will blame BMW's faulty product. It's already happened to people.
For the OP, if you buddy just wants a little more power, the first thing is DON'T let the dealer do any reflash of the ECU since the newer versions introduced considerable lag. There's a "fix" out but many have said the fix doesn't last. They did this to try to extend the life of the waste gates which go bad ALL THE TIME.
For modest gains you can feel, just get a Turbo Timer used on E90post. They sell for as little as $120 to $150. It's not detectable and very safe. It's pretty easy to install once you know how to get to the TMAP sensor.
For more potential power, there's the JB+. It will allow more boost at the risk of setting off some alarms if his car has the newer software. You can adjust the amount of boost you want based of factors such as fuel octane. This unit also goes on the TMAP sensor.
For more power, there's the JB3, which is constantly being updated with new maps.
The major competitor would be the Vishnu unit, which is more sophisticated. Both require you to open the ECU, which isn't too hard, but is more work. You just plug these units in the ECU connectors and place the box in the ECU enclosure.
Old Nov 11, 2009 | 02:37 AM
1sleeper's Avatar
1sleeper is infamous around these parts1sleeper is infamous around these parts
^^^ All good info. The JB+ actually offers a reasonable bump in HP with very little fuss. Either of the piggyback options are fine as well. JB3 and PROcede (Vishnu) really change the car but do require a little more work (really nothing much, 30min- 1 hour MAX).
Old Nov 11, 2009 | 04:16 AM
kailuaboy's Avatar
a good friend of mine lost an engine on his 335 with a dinan reflash and within 2days they had it worked out and a new enigine on the way....mind you the car was not back for 3 weeks but it was less than 2 days for the two to figure their sh*t out. im sure there are other case that involve supporting mods and so on and i know bmw can be hard to deal with in such cases but from what ive seen dinan isnt nearly the issue that any other tuner could be.
Old Nov 11, 2009 | 09:36 AM
NewSong's Avatar
NewSong is a name known to allNewSong is a name known to allNewSong is a name known to allNewSong is a name known to allNewSong is a name known to allNewSong is a name known to all
Exclamation
I'd be more worried about the HPFP issues. A lot of Bimmer fanboys tend to skip over this fact that some people have been left in the middle of traffic with very little power available to them at the wheels.
Old Nov 11, 2009 | 04:52 PM
1sleeper's Avatar
Having two cars with this motor I guess I would qualify as a "fanboy", but not a day goes by I start one of those cars and hope I dont get the "long crank". Really is a dopey problem that this far into the model cycle, they dont have it fixed. Great motor outside of that. Seems there are a few solutions coming from the aftermarket but still.
Old Nov 11, 2009 | 05:25 PM
NewSong's Avatar
Cool
It's kind of sad BMW hasn't been able to (or is unwilling) to fix this problem with a more long term solution than "We'll replace it."
Audi admittedly has their own problems with their direct injection system (carbon build up), but at least it won't leave you stranded.
Old Nov 11, 2009 | 06:37 PM
1sleeper's Avatar
Hey, the bright side is, assuming your fuel pump works that 6 with the 2 little turbos can do things like this.....http://www.youtube.com/watch?v=4y0KxOkJcjs
Old Nov 11, 2009 | 06:43 PM
NewSong's Avatar
Cool
Yeah but any built car is going to be pretty super. How much does an ASR built 135i cost?
Old Nov 12, 2009 | 03:25 AM
1sleeper's Avatar
The ASR upgrade isnt quite out yet, but I am hearing its 2500-3k. Supposed to be a bolt-on upgrade. I would guess with upgraded IC, DP, exhaust, and a few other supporting mods, you are probably looking at 7k or so.
Old Nov 12, 2009 | 05:28 PM
aus's Avatar
aus
Agreed.
And the carbon build up is on the N54 too.
PV=nRT.
Sep 9, 2022 06:06 PM
takenotes996tt
Jan 20, 2016 06:34 AM
HotRod
Sep 10, 2015 07:17 PM
pjb84
Sep 2, 2015 12:57 AM
