[Vid] Modded E92 M3 DCT Vbox Results
Old Nov 15, 2009 | 11:45 AM
DLSJ5's Avatar
DLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond repute
I did some Vbox pulls today and managed to edge out my 10.87 wtih a 10.80 flat but on a flatter slope, 2.9 vs. now a 0.95%.
There was some slight wheel spin from 1st to 2nd that slightly does affect the time, so there is room for improvement with traction. But even more so I did a bit better in one run but missed 130 by 1.7 MPH! That run would could have been a 10.6. Lifted too early. From 60-120 I was .2 tenths ahead of the 10.8 run, oh well doesn't count unless you hit 130, still very happy with the results.
I was also very happy with the 1/4 mile results on street tires, more so the traps as I could not launch, I had to go half throttle then get into it, but would always experience some wheel spin on the 1-2 shift, but I managed to hit:
60' - 2.32
1/8th - 8.24 @ 95.59 MPH
1/4 - 12.41 @ 119.55 MPH
With a good launch and solid conditions, 11's are easily doable on the Vbox, but we'll see if it translates to the track.
On the Vbox screen it said 12.2, but I was using the 1 foot rollout function which actually simulates real world 1/4 mile tracks,but the Vbox does not measure it that way in the graph for some reason. Here's a vid-
http://www.youtube.com/watch?v=tCGPZqwC258
Old Nov 15, 2009 | 12:40 PM
hotrod182's Avatar
hotrod182 is infamous around these parts
60' - 2.32
Nice Runs! You should just set up the Vbox to beep at 130mph. It makes it easier. Did you set up the 60-130 split on the "accel 2" screen? Your car is flying!
Old Nov 15, 2009 | 12:53 PM
DLSJ5's Avatar
I will do that next time, thanks Brotha. There's still some functions on there I'm not sure of, next time in Mexico you gotta show me the best way to set it up for that.
Old Nov 15, 2009 | 02:00 PM
st06m3's Avatar
st06m3 is infamous around these parts
Good runs Drew! You probably have one of the fastest N/A e92 M3's around.
Old Nov 15, 2009 | 02:45 PM
Murtaza's Avatar
Murtaza is infamous around these parts
Great stuff buddy!
Old Nov 15, 2009 | 05:06 PM
CURI0's Avatar
CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !
Can't wait to see how that Vbox stacks up to the real thing
Old Nov 15, 2009 | 06:49 PM
DLSJ5's Avatar
Thanks J, can't wait to see the 2.5 in action, hope you break Scott's record!
Originally Posted by Murtaza
Great stuff buddy!
Thanks man, next week should be fun!
Old Nov 15, 2009 | 06:51 PM
DLSJ5's Avatar
From what I've seen they are very close, it seems the traps are a tad lower at the track, and the ET's are a tad better, lol, you never know, but I'd take a slip over a Vbox chart any day!
Should be fun next weekend, can't wait to see how your new setup does!
Old Nov 15, 2009 | 09:49 PM
hotrod182's Avatar
I usually bring my Vbox to the dragstrip to compare the numbers. They are very very close. Usually it will round up on the ET. So if it says 12.0, your timeslip will often say 11.97 or something. The MPH reads a little higher. Famoso will usually read about .9mph slower than the Vbox, and Sacramento about .6 mph slower. But that mostly has to do with the way the speed is calculated. The Vbox reads the speed right at the finish, the dragstrip is calculated by the time it takes to go across the distance between the trap lights. You might almost say the Vbox is the more accurate method. I can seriously detect a difference between left and right lanes at times. One lane will consistantly deviate a different mph compared to the other. Either way, it is pretty consistent. You simply figure in the mph adjustment, and you can pretty much know what your time slip is soon as you cross the finish line.
Old Nov 15, 2009 | 10:02 PM
DLSJ5's Avatar
Thanks Bro, if anyone would know it's you, flat out impressed with what you have done with your car.
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
