Hardwiring V1
Old Feb 17, 2011 | 11:51 PM
Chris 23's Avatar
Chris 23 is infamous around these parts
Hardwiring V1
I know this has probably been covered millions of times, but I was looking to hardwire my V1 tonight, and was wondering if anyone with a 987.1 Boxster has done this yet. Is there a certain wire I can use in the fuse box without having to splice a wire or any other easier way to hardwire the V1? Again, sorry if this has been covered tons of times before, but any help would be great. Thanks in advance.
Old Feb 18, 2011 | 06:22 AM
jmc777's Avatar
jmc777 is infamous around these parts
Use one of these. No splicing necessary. I used these in my 987 for ipod integration. http://www.amazon.com/Littelfuse-FHA.../dp/B0002BGELQ
Old Feb 18, 2011 | 05:02 PM
lithium1330's Avatar
lithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud of
Not sure if about the specific wire that's part of the car - I'm sure any wire will give you the 12v, but you need to figure out which one is constant and which is switched. You probably don't want that anyways, since that approach means you're cutting into a wire in the factory wiring harness.
If you have a spade, you can just wire the V1 hardware adapter to the fuse box directly. Here are two fuse locations I use which will power-on when key is turn to the on position. If I decide to remove the v1, I just unplug this spade, pull the wires and it's done.
Old Feb 19, 2011 | 08:28 AM
ccbesq's Avatar
ccbesq is infamous around these parts
Originally Posted by jmc777
Use one of these. No splicing necessary. I used these in my 987 for ipod integration. http://www.amazon.com/Littelfuse-FHA200BP-ATO-Add-A-Circuit-Kit/dp/B0002BGELQ
There various versions of these at any auto parts store - they're called fuse taps. Here's the way I did it (for Valentine, Garmin and Dension):
Old Feb 22, 2011 | 06:35 PM
Chris 23's Avatar
Just did the hardwire today..it was so simple with the add a circuit. Thanks for the help guys.
Old Mar 26, 2011 | 05:53 PM
smshirk's Avatar
smshirk is infamous around these parts
Even better from this
Old Mar 27, 2011 | 02:03 PM
I place the concealed display in front of the gauges. It's in the line of sight of the road and gauges. Only downside is glare from sun when the top is down.
Old Apr 2, 2011 | 10:16 AM
infantrytroop22's Avatar
infantrytroop22 is infamous around these parts
Originally Posted by ccbesq
Attachment 144263
Which of these is constant and which only switch on with the ignition?
Old Apr 3, 2011 | 09:20 AM
If you have a 987, check my picture above... The two I used should be open for use and switched.
Old Jun 26, 2012 | 07:29 PM
ISST's Avatar
ISST is infamous around these parts
So if I have this correct, you just placed a single spade on one side (switched) and just used an inline fuse? Thx
Old Jun 26, 2012 | 09:33 PM
That's what I did. The V1 inline wire should have a fuse built-in (IIRC - the white tube looking thing).
Old Jun 27, 2012 | 03:53 AM
ISST's Avatar
Excellent. Thanks
doughsun
Jan 31, 2016 04:22 PM
XLR82XS
Oct 5, 2015 07:02 AM
panas001
Sep 27, 2015 02:51 PM
markj
Sep 11, 2015 11:29 AM
markj
911
Sep 1, 2015 08:20 AM
