987 performance upgrade
Old Mar 10, 2012 | 11:48 AM
redline1's Avatar
redline1 is infamous around these parts
I have a 2007 Boxsxter S with the 295 hp/ 251 fpt engine. What is the best combination of upgrades available to boost hp and fpt within a $3000 budget?
Old Mar 10, 2012 | 12:06 PM
onurleft's Avatar
onurleft is infamous around these parts
If i'm not mistaken I saw this in European Car..
You can add a different intake plenum, full exhaust and have Revo tune the car and I believe the gains are around 30 break horsepower give or take maybe more. It would probably cost around 3-4k.
Old Mar 10, 2012 | 12:12 PM
TighTT's Avatar
TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !
I really love my EVOMS RS370 package. Drives like a different car.
Old Mar 10, 2012 | 12:13 PM
2slow2speed's Avatar
2slow2speed is a jewel in the rough2slow2speed is a jewel in the rough2slow2speed is a jewel in the rough2slow2speed is a jewel in the rough
From one of 6speed's sponsors:
http://www.vividracing.com/catalog/s...8-p-65942.html
Should work on Boxster's as well.
Pretty much a DIY project if you are mechanically inclined and comfortable using a PC.
If you ever decide to go this route make sure to read up about the possible issue with the shifter cable becoming loose due to the re-routing of the left shifter cable. More information can be found over at planet-9.
Then if you are up to it, remove the 2nd set of catalytic converters on your stock exhaust via a mod from Carnewal.
Old Mar 10, 2012 | 02:36 PM
Fluid987's Avatar
Fluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond repute
+100% on that ... Add some fabspeed catless headers and you are pushing a 50HP increase
Old Mar 11, 2012 | 05:53 PM
CampioniShop1's Avatar
CampioniShop1 is a jewel in the roughCampioniShop1 is a jewel in the roughCampioniShop1 is a jewel in the roughCampioniShop1 is a jewel in the rough
The Gen I S cars respond very well to a cat-back + tune setup. If you can chime in a plenum as well, you will see close to 40whp gains.
Cat-backs alone gain upwards of 15whp!
Let us know if we can be of any help - we have done a ton of Caymans on the "other" forum.
Old Mar 11, 2012 | 09:15 PM
PaulR's Avatar
PaulR is infamous around these parts
I have a gen.1 Boxster S and I just did the Desnorkel mod (finished about 2 hours ago) and I can confirm it does seem to liven up throttle response and give a more robust engine note under full acceleration. I used wire mesh over the inner plastic housing as well as on the back of the stock side vent to adress my concerns with debre getting into the snorkel. I painted the side vent and mesh black... looks and sounds good all for $20 and 2 hours time.
Next mods will be IPD plenum + TB + Fabspeed race catback + chip and either evo's or Fabspeeds air intake. I will be installing these mods all at the same time in about a month from now and will report on the result compared to stock.
Old Mar 13, 2012 | 12:32 PM
redline1's Avatar
Boxster performance upgrade
Thanks to everyone for their input.
albert@velosdesignwerks
Bentley
Dec 24, 2018 09:46 PM
ECS Tuning - VW
Aug 21, 2015 09:11 AM
ECS Tuning - VW
Aug 20, 2015 02:01 PM
Aug 20, 2015 12:17 PM
Jakk55
Aug 20, 2015 05:47 AM
