Glove box Problem
Old Dec 20, 2007 | 10:15 AM
cayenned's Avatar
cayenned has a spectacular aura aboutcayenned has a spectacular aura about
Glove box Problem
I was wondering if anyone has had the same or similar situation happen to them. My glove box won't open. It seems as if when you press the button it doesn't unhinge the lock. It isn't stuffed either, but it does have my trusty valentine and sunglasses in it. Is there a solution besides having to take it to the dealer to do it? I would look in the manual but.....its in there too.
Thanks guys
Old Dec 21, 2007 | 09:42 AM
cayenned's Avatar
anyone????
Old Dec 21, 2007 | 11:15 AM
hk_usp9f's Avatar
hk_usp9f is infamous around these parts
Did you try locking and unlocking it then pressing the button? The locking mechanism may have jammed.
The button feels "disconnected" is when it is locked.
Old Dec 22, 2007 | 01:12 AM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
It sounds like the latch has failed, and will have to be replaced. Easy job, and you can get into the glove box with a small pick to slide the catches back in the middle. Only one side has to be depressed, as it works both sides at once. This will make sense once you see how it works. Once open, you can remove the glovebox to replace the latch. Put the key in the hole to keep the tumbler from falling apart, otherwise you will have a mess.
Old Dec 23, 2007 | 09:37 AM
cayenned's Avatar
Thanks guys, ill try what speeddem suggests and if not then take it to the dealer, thanks for the input!
Old Dec 23, 2007 | 11:21 AM
mudman2's Avatar
mudman2 is infamous around these parts
This is a common problem, I replaced mine a few weeks ago, bad quality problem from the supplier. The whole part cost $12 as its a supplier problem.
If you remove the trim strip above the glove box, you van pick the lock with a small screw driver. Angle from the left to right slightly down.
Old Dec 25, 2007 | 11:11 AM
cayenned's Avatar
I followed porschespeeddem advice and was able to open it so I took out my valentine, car license, and sunglasses out of the glove box. Ill take it by the dealer soon to have my 40k service done and will take care of it then.
Thanks for your replies and help guys, happy holidays
Old Aug 25, 2011 | 06:20 PM
andrewgarland's Avatar
andrewgarland is infamous around these parts
cayenne glove box
My glove box is stuck closed too. I will attempt to do as the other cayenne owners here have done. Thanks for all the great input. Ill give a follow up too.
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
