Plzz Help ...!
Old Jun 1, 2008 | 04:40 PM
CayenneOFDeatH's Avatar
CayenneOFDeatH has a spectacular aura aboutCayenneOFDeatH has a spectacular aura aboutCayenneOFDeatH has a spectacular aura about
Plzz Help ...!
heey guyz i have a highly modified 06 CTT .. and it keep stoping on me everytime i mean from stop light to another like i take off well but when the RPM reaches 2 it stop and goo baq to Zero and the speedometer 2 then it launches again till i reach a full stop @ a stop light and again and again i thought it was from the induction kit i had on i took it off cleaned it and put back again and was sure there wasnt any air leaking but yeasterday it happend again but the diffrence is that the car stoped and wouldnt move till i turned it off and started it again
plz help tell me wht 2 do
thnx in advance
Old Jun 1, 2008 | 07:35 PM
lager99's Avatar
lager99 is infamous around these parts
I have no idea what you just said.
Old Jun 2, 2008 | 01:36 AM
canberk's Avatar
canberk is infamous around these parts
Okay, if I understood you correct, your car is stopping constantly, you can't idle your car. Correct? If so, then according to my past experiences, there are three possibilities.
First and the strongest one is the air quality sensors made by Bosch that can be found at the air intakes. Open the engine hood and voila, they are in front of you. You'll need to replace them. There are two, and each are around 300 bucks. Before buying the new ones, make sure you test it with a friend's cayenne. Also, you can test it just by unplugging them and starting the vehicle without air quality sensors. They are easy to unplug.
Any model year and any model will work (V6,S,Turbo, all the same) for borrowing. You can also test it with Mercedes-Benz air quality sensors. All made by Bosch.
Second possibility (Also strong): Bad induction coils, replace the coils and try again.
If you can move the vehicle after starting, then probably bad coils since the air quality sensor will not let you take off, but in some cases, it will, so it's better to test both cases.
Old Jun 2, 2008 | 02:25 PM
SeattleBum's Avatar
SeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud of
That was the run-on sentence of death.
Old Jun 2, 2008 | 05:54 PM
mlc.design's Avatar
mlc.design is infamous around these parts
Lmao :d
Old Jun 2, 2008 | 07:54 PM
jej3's Avatar
jej3 is infamous around these parts
ROFLMAO (which is close to a run on sentence )
Old Jun 3, 2008 | 05:02 PM
thnxxx alot for who helped ;D
Old Jun 3, 2008 | 06:00 PM
mlc.design's Avatar
I apologize cayenneofdeath us guys just need a haha every now and again get away from the real world
BTW i love you cayenne
Old Jun 4, 2008 | 02:42 AM
canberk's Avatar
was i the only one who took this thread serious?
007 Vantage
Oct 8, 2015 08:35 PM
Sales@RSW
Lamborghini
Oct 1, 2015 02:01 PM
Vincent997S
Sep 17, 2015 06:45 AM
