New product lowering module
Old Jan 23, 2009 | 07:06 AM
  #256
mattjtaylor50's Avatar
mattjtaylor50 is infamous around these parts
plenty of discussion regarding "why" in previous threads
links just trick the car's ride height sensors to a lower level
the module does that but also changes compression/pressure in bags electronically
Old Jan 24, 2009 | 03:00 AM
  #257
NanaimoCTT's Avatar
NanaimoCTT is infamous around these parts
but isn't the only way to "lower" the car is to release the air in the bags? Aren't the sensors the electronic way of changing compression/pressure.
Old Jan 24, 2009 | 11:12 AM
  #258
globalm3's Avatar
globalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond repute
DAS Wagenz.. seemed like a add for your lawfirm until you edited it..
Old Jan 24, 2009 | 05:02 PM
  #259
ALPINE_997's Avatar
ALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to behold
DAS thanks for your opinion. It was noted and suspect at best.
Global - I didn't read the unedited version. hmmm
Old Jan 30, 2009 | 08:01 PM
  #260
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
Alpine, the spare climate control module arrived... PM me on the switch you need from it.
David
Old Feb 1, 2009 | 10:11 AM
  #261
Jeff SD's Avatar
Jeff SD is a jewel in the roughJeff SD is a jewel in the roughJeff SD is a jewel in the rough
Originally Posted by DASWagenz
I wasn't to sure when I ordered, seemed too good to be true.
Ordered mine 5 days ago, and got it yesterday and it works!
I spent $200 today just driving every twisty road I could find. Product looked wierd when I received it, but as advertised I installed it in about 5 min. The directions were simple, I plugged it in under the passenger seat and screwed in two safety screws. There's a **** which turns the module on/off to allow the use of the loading level, other than that works just like stock when switched off. Ride is better than the adjustable links or the Renntech Module I just paid to take off because of tire rub/wife complaints-harsh ride.
I'm running 22in sport technos on a 06 Turbo S with no rubbing at all, and my damping adjustments still work like stock.
I've spent over $4600 in parts and labor trying to get the look and ride that this thing did in 5 min for $615 bucks including shippping. No brainer here, go get one before they raise the prices, I would have paid five times the amount had I known about them first.
BTW-Anyone interested in a Renntech Module or Adjustable Links?
I'm starting to have second thoughts about installing the Techart Module. For the price, the ST module appears to be the best bang for the buck.
Are you throwing any warning codes?
Old Feb 1, 2009 | 10:21 AM
  #262
Jeff SD's Avatar
Disregard my question..I found your answer here>>>Only drawback is a warning light on the dash display when the unit is turned on which acts kinda like a safety feature so you know your at minimum clearance, but I can live with that because it works so much better than everything else I've tried.
Old Feb 2, 2009 | 11:41 AM
  #263
jchou38's Avatar
jchou38 has a spectacular aura aboutjchou38 has a spectacular aura about
i am definetely, getting this today!!!!
Old Feb 2, 2009 | 11:43 AM
  #264
jchou38's Avatar
Just ordered, can't wait for them to come in!!
Old Feb 12, 2009 | 08:39 PM
  #265
TurboSPeng's Avatar
TurboSPeng is infamous around these parts
more picture
i'm still interested in know more about this piece. some of you posted some nice pictures of the part..but no one took pictures of the back side. can someone post pictures of the back side of this piece. also does this piece require any wire connection? or does it just plug into the nozzle with a on/off switch.
thanks
Old Mar 24, 2009 | 01:17 AM
  #266
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
guys i've read all the thread from beginning and to be honest im shocked how some tuners charge 600$ for a trick
i used to have another trick to lower my cayenne Turbo it's i open the fuse box next to the passenger door it located exactly behind the air vent next to the door and pull off one of the fusses which will disconnect the lowering and will make the vehicle remain on the level u already set
Old Mar 24, 2009 | 01:18 AM
  #267
yalmutawa's Avatar
but it makes u feel like u are in a mixer it become un drivable and it jumps very ruffly
Old Mar 24, 2009 | 03:28 PM
  #268
golo's Avatar
golo is infamous around these parts
which fuse i need to pull and any warning lights?? thanks
Old Mar 24, 2009 | 07:10 PM
  #269
yalmutawa's Avatar
yellow one in the middle sorry i sold the car dont have it any more otherwise i would take some pix and post them for u
Old Mar 25, 2009 | 12:06 AM
  #270
cayenneturbo06's Avatar
cayenneturbo06 is infamous around these parts
Ok... So whats the final verdict. I'm itching to lower my cayenne and really would like to avoid spending the cash on a techart module... At first people were saying that they liked this thing than someone said it was shady and wanted there money back. Can someone tell me whether I can confidently buy this thing or not?
