What radar detector would you guys recommend?
What radar detector would you guys recommend? What is the most economical one and just the best out there? also What is the difference between a laser and radar detector?
Thanks for your help
Escort 9500ix or the more expensive 9500ci. Both models have laser and radar detectors built in.
I've had the V1 for many years and got tired of the many false alerts (it's rather noisy). Been very happy ever since I swapped to the 9500. No false alarms and the GPS and red light camera feature is great. This thing is quiet which I love until it needs to make noise. I also like that you can hook it up to your pc to update it. Definitely state-of-the-art.
I have the valentine 1 for radar detector and blinder m47 for laser jamming! Gus over at Technik1 did a stealth install which is very very cool So far real happy with all! Completely unrelated, i got a stupid "no through traffic from 7-10am ticket this morning while I was playing with buttons & rolling along behind a nyc taxi - ugh). The moral of the story is regardless of detectors you still need to pay attention! cheers
V1's in each vehicle, works GREAT and with DIRECTIONAL ARROWS.
I then have a laser interceptor for a jammer in each.
with BOTH, my cars are undetectable for Laser and a lot of lead time for the radar.
ZERO TICKETS since I have had them installed.
laser intercepted is for laser
at least that's how I use mine..
Best of both worlds.
Cab here are my install pictures on my GTS per your PM.
If you want an explanation of the wire install here it is:
First of all DO NOT CUT THE wires for the LI.
My install guy did that at first for the front ones, and then when he tried to melt them back, no workie.
DO NOT CUT.
2nd, run the two wire for the front, through the little hole under the dash, through the sound wall up the drivers side to the grill.
The back ones, BARELY make it, not as long as they should be, but they did.
run them up the side, behind the airbags, along the edge of the driver side, all the way to the back.
take apart the back hatch, and run through the holes for the rear license plate lights.
My install was seamless and perfect.
the place for the switch was perfect for me, but you can choose a different spot if you wish.
DO NOT CUT.
