problematic cayenne thread
Old Feb 1, 2010 | 04:47 PM
vduzin12's Avatar
vduzin12 is infamous around these parts
As I am in the market for a cayenne gts, I want to know what I'm getting myself into. I know WayneE has had a few problems with his. Lets compile a list of problems whether recall or warrantied. I hope to get alot of feed back on this
Old Feb 1, 2010 | 05:13 PM
jyupitt1's Avatar
jyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond repute
I have a 09 Cayenne S 8900 miles. So far issues with auto headlight leveling and coolant leak.
Old Feb 1, 2010 | 05:21 PM
manishdutta's Avatar
manishdutta has much to be proud ofmanishdutta has much to be proud ofmanishdutta has much to be proud ofmanishdutta has much to be proud ofmanishdutta has much to be proud ofmanishdutta has much to be proud ofmanishdutta has much to be proud ofmanishdutta has much to be proud ofmanishdutta has much to be proud of
08 GTS, 10,000 mile and only issue has been my driver side mirror wasn't auto dimming, turned out to be a loose contact.
Old Feb 1, 2010 | 05:57 PM
vduzin12's Avatar
the coolant leak appears to be across the board
Old Feb 1, 2010 | 06:22 PM
hulahula's Avatar
hulahula is infamous around these parts
Not a GTS but for my 2005 CTT hasn't been trouble free,
28k - Electrical problem (fixed under warranty)
34k - Turbo diverter valve leak (replaced under warranty)
34k - Headlight failure (corrosion on connectors. replaced under warranty)
34k - Headlight washer malfunction (fixed under warranty)
35k - Air Compressor warning light (replaced under warranty)
38k - Ignition coil failure (replaced under warranty)
38k - Rear wiper blade taken off by car wash ($150 parts/labor)
45k - Horn failure (not fixed yet).
Old Feb 1, 2010 | 06:35 PM
Cpa4S's Avatar
Cpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to behold
18 months on the GTS and spotless
Old Feb 1, 2010 | 07:57 PM
the head's Avatar
the head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the rough
58k miles on mine, but I bought it CPO with 38k miles. TPMS system required 4 visits to get that fixed, coolant pipes, cam sensor, cam actuator solenoid, coils replaced, water leak/drains clogged (didn't really fix the leaking spot - I had to do it myself), wheel speed sensor, cardon shaft (driveshaft), thermostat replacement (stuck open), rear seats would not fold up - they had to unbolt them to free up the mechanisms, EVAP cannister mechanism failure, and a rear door that would not lock. All of these covered under warranty.
Those are the things I have taken it in for. Here's a list of things that are bad but I haven't bothered - headlight 'gaskets' deteriorated to almost nothing and rear hatch struts do not lift the gate all the way up without help. Things on the horizon: radio occasionally goes silent and you have to turn the key completely off and remove it to "fix" it. It's done that maybe 3 times since I've owned it. There is a door in the HVAC sticking that sometimes does not let the air flow where you want it to. Rough idle when starting it up hot for a few seconds. Oil leaking from the vent line under the y-pipe on the inlet.
I have until October this year for the CPO and you can bet I'll get as much fixed as I can find prior to then.
Old Feb 1, 2010 | 09:20 PM
bbywu's Avatar
Air suspension failure. Repeated "Air Suspension Faults" due to air leak from the system or compressor. You can buy the VW rebuild kit to save a little cash, rather than replacing the entire unit if it is out of warranty.
Old Feb 1, 2010 | 09:27 PM
huskyfan23's Avatar
huskyfan23 is infamous around these parts
Had a pin-sized hole in a cylinder head. $9k repair covered under warranty. Moral of this thread? Make sure you have a warranty!
Besides that, it's been great to me.
Old Feb 2, 2010 | 09:07 AM
vduzin12's Avatar
^^^^^^I agree 100%. It sounds like owning one of these w/o a warranty is like playing Russian Roulette. I'll definitely get a cpo and be sure to get rid of it before the warranty expires!
Old Feb 2, 2010 | 09:17 AM
WayneE's Avatar
WayneE is infamous around these parts
I think that applies to any of the expensive/complex German cars. Way too many unreliable systems that can go haywire and cost you a lot of money in diagnostics and repairs.
If you buy used, definitely go CPO.
Old Feb 2, 2010 | 10:23 AM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
2008 cayenne GTS, 27,000 miles problem FREE
Old Feb 2, 2010 | 12:20 PM
skier's Avatar
skier is infamous around these parts
08' GTS 38,000 miles - no issues other than scratches, dings, ripped leather, from ski equipment in and outside of car.
Old Oct 30, 2010 | 11:20 AM
smokersteve's Avatar
smokersteve is infamous around these parts
Hello, I have a leak in the unit between the engine and the transmission, it leaks very fast. It happend when I did a brake boost launch.
It leaks out of the threaded holes at the bottom of the houseing that bolts between the eng and trans.
2004 cayenne s 80,000 miles.
Not sure if I can fix it or where is is coming form
NC 996TT
Mar 23, 2023 06:19 AM
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Long Islander
Jul 13, 2017 07:50 AM
smartbot
May 16, 2016 12:35 PM
