New Pads / Rotors
Old Mar 16, 2010 | 10:49 PM
ikold's Avatar
ikold is infamous around these parts
New Pads / Rotors
Curious what everyone is getting out of a set of pads ? How often do you have to install new rotors.
What are folks paying for pads and rotors. Have been surprise by how little life these rotors have.
Old Mar 17, 2010 | 05:55 PM
reguru's Avatar
reguru is infamous around these parts
Paid roughly $450 for the rear from my local indy shop. Dealer wanted over $900 for the same job.
Old Mar 17, 2010 | 06:42 PM
Beast's Avatar
Beast is infamous around these parts
Yeah, it's crazy how fast they wear. I've started to stockpile front & rear pads, cables, and one additional set of rotors.
Old Mar 18, 2010 | 11:45 AM
ikold's Avatar
Shop
Was just told by the shop
Front rotors pads are due on my CTTS (61k miles).
$2,163 parts labor
777 per rotor
281 for four pads
140 for new brake fluid.
410.22 for 60k
Old Mar 18, 2010 | 11:49 AM
ikold's Avatar
Does this seem reasonable ? Seems very pricey to me.
Can anyone recommend a good indy shop in Denver/Boulder .
J
Old Mar 18, 2010 | 12:55 PM
Beast's Avatar
Sounds like your getting hosed to me. Are your replacing Brembos? If so, it might be legit. I replace OEM only, but I have a V6 too. Check to see what the prices are for your CTTS. If anything , the 60K service is a great deal.
http://www.suncoastparts.com
Old Mar 18, 2010 | 01:22 PM
yoojeankim's Avatar
yoojeankim is infamous around these parts
J
Orrin at Eurosport in Englewood 303.789.2545
how often do you guys have to change the rotors/pads? i just got a CTT with 55k miles
Old Mar 18, 2010 | 03:45 PM
ikold's Avatar
Is the Turbo S rotor a 350mm rotor ? is there anything else special about them I need to know when ordering them.
J
Old Mar 18, 2010 | 04:39 PM
mike pezely's Avatar
mike pezely is infamous around these parts
Find a good indy. Call Jeff Clark at Sunset Porsche and tell him what you are doing. He will set you up with all the correct OE parts and you save a BUNCH. Take your family out to dinner with the savings!! Mike
Old Mar 18, 2010 | 04:57 PM
dajadeturtle's Avatar
dajadeturtle is infamous around these parts
CTTS is a two piece rotor, CTT CS or C are a single rotor that just increases in size diameter and thickness as you move up by model...
I just replaced all four rotors (Zimmerman) oem Brembo pads and sensors for call it $800.00... labor used my buddies shop lift... big help... not a difficult job a 4 out of 10 in difficulty no special tools needed except for the rear disc replacement the Volkswagen tool is needed... thats what I call it...
I changed the front pads twice and the third set I started to get the lip... but i never cut the rotor and it never warped or shook under braking...
The rears wore out two sets of pads and got the lip...
I have put maybe 600miles of mostly highway since replacing them and here is a breakdown of how it went...
20K fronts (maybe 21K) 1st replacement OEM dealer that's when she did 75% hwy
30-32k fronts and rears 2nd replacement front 1st replacement rear OEM dealer 50%hwy & stop go city traffic...
45K-47K I did the fronts OEM again
60K the job I just did... rotors plus pads...
I used OEM pads from Porsche with OEM sensors from Porsche... the after market price and the dealer shop price is close enough for me to keep it factory even though I can't deal with the dust the factory stuff leaves... I know when I squeeze the anchors it bites and stops... and without worry.. I will give a more detailed report on the rotors whenI need to change pads probably by 75K and I'm guessing that number because she is driving more highway again....
Old Mar 19, 2010 | 03:50 PM
medtech's Avatar
medtech is infamous around these parts
Easy DIY if you have space and tools.
Old Mar 19, 2010 | 04:27 PM
Justahonda's Avatar
Justahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud of
I find if you dont replace the rotors at the same time as the pads you end up replacing the new set of pads prematurely due to the lip that has formed on the rotor at this point wears into the sensor in the pad before it should. Just a tip for the DIYers
Old Mar 20, 2010 | 07:10 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
J
Turbo S uses a 2-piece 380mm rotor, and they are substantially more expensive to replace than 1-piece non turbo S brakes. I just added Turbo S front brakes to my 2004. Calipers, backing plates, rotors, and pads. I have my sensors bypassed because I don't want to mess with them, and I check my brakes often. To my knowledge, Orrin has not been with Eurosport for some time now. I believe it was around the turn of the year when he left.
Edit: Does anyone know of any place selling aftermarket, perhaps less dusty, Turbo S front brake pads?
Old Dec 5, 2011 | 04:32 PM
FlyYellow's Avatar
FlyYellow is infamous around these partsFlyYellow is infamous around these parts
Does anyone know of any aftermarket brake pads for the 380mm CTTS that are less dusty and perhaps a bit quieter?
Old Dec 5, 2011 | 06:11 PM
I have been using EBC Red Stuff for quite a while and they seem to be very good. They're silent most of the time but i do get a light chirp once in while at 3-5mph.
