How to remove shift knob?
Old Mar 31, 2010 | 10:55 AM
pafnucy's Avatar
pafnucy is infamous around these parts
How to remove shift ****?
Thinking about replacing a shift **** on auto Cayenne 04. Does anyone know hot remove the **** from the shaft?
Old Mar 31, 2010 | 04:00 PM
xTapouTx's Avatar
xTapouTx is infamous around these parts
I'm also pondering this.
To add to this question my park release lever/botton is damaged and kind of sticking out. Anyone have any good suggestions on getting it back in or repairing in somehow?
Old Mar 31, 2010 | 06:02 PM
nelsonmx's Avatar
nelsonmx is infamous around these parts
As per the manual:
Selector to the D (drive) position. Do NOT push in the release lever and pull straight up on the **** and it should slide off......
I have not done this myself yet, so please let us know how it goes. I want to take mine off as I have a carbon piece to install around the shifter.....
Bob
Old Apr 13, 2010 | 02:14 PM
xTapouTx's Avatar
Do not do this at a bank drive through just to see if it works....because it does...but it's not as quick and easy to get back on!!!
Do know that you can still drive with it and shifting is not a huge issue as long as you can get a good grip on it.
Old Apr 13, 2010 | 02:35 PM
bcherry's Avatar
bcherry is infamous around these parts
do it in Neutral, let chances of moving with out being able to take it out of gear...
Putting it back on: i had to pull the button on the **** "out", in the opposite direction you would push it in to take it out of park, in order to get it to go all the way back on...
Hope this helps.
Old Apr 13, 2010 | 03:00 PM
xTapouTx's Avatar
Hope this helps.
Ahhh I'm sure that will help many people out. My spring is broke in there so I had to use a small screw driver to hold it back when putting it back on. (That was the whole reason I was taking it off was to see if I could fix the "play" in the button)
Old Apr 13, 2010 | 06:41 PM
nelsonmx's Avatar
Well.......I'm glad the manual procedure works, but I'll remember not to do at the Bank drive through!! Too funny
Old Apr 15, 2010 | 07:16 PM
Cpa4S's Avatar
Cpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to behold
i thought it was to go into neutral as well? anyway, yank like h#ll straight upand it pops off
smartbot
Jul 18, 2016 01:15 AM
davetherave
Bentley
Sep 16, 2015 06:30 AM
sparks
Sep 8, 2015 03:03 PM
AM v12v
Sep 4, 2015 02:52 AM
