COMPLETE CAYENNE LED Interior Light Change-Over Tutorial
Old Aug 20, 2011 | 11:22 PM
  #31
mbagge01's Avatar
mbagge01 is infamous around these parts
bad light
I have been undertaking this led replacement in my 04 cayenne tt and noticed that the middle light located in that cluster of 3 in the front by the home link buttons does not work. I have checked it with opening the door and that accompaning switches. The passenger and Driver lights next to it work fine but getting nothing out of that middle light with a normal bulb or led. Is there a fuse that goes specific for that light or a way to test if it is getting power?
Old Aug 24, 2011 | 12:15 PM
  #32
gearheinz's Avatar
gearheinz is infamous around these parts
im going to have to do that!
Old Sep 21, 2011 | 12:28 PM
  #33
Juejaimon's Avatar
Juejaimon is infamous around these parts
i don't think its a bad light, i had the same problem. I had to turn the bulbs 180 degrees and reinsert it in. Might be + and - issues. Also if you hit the dim functions on that console, they bulbs will stop working for 5 to 10 minutes until it resets for some odd reason. so as long as you don't hit the dim functions, you should be okay.
Old Sep 22, 2011 | 02:40 PM
  #34
FastHackem's Avatar
FastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud of
ROX: Those LEDs make your interior look AMAZING!! I think this would be a great conversion for the DIYer and mainly for the black and grey interiors. Mine has the peanut butter interior and I really like the way the halogens look. I feel like if I changed them to LEDs, it wouldn't look right and it would take away the warmth of the interior environment.
Old Sep 22, 2011 | 06:52 PM
  #35
roxboxxx's Avatar
roxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant future
Thanks man. Why don't you buy 2- 4 bulbs for the main front seat overhead and try it out. Its the easiest to replace and you will be in for the price of a meal. The front overhead casts enough light to give you a good idea of what the cabin would ultimately look like. Worst case, you blew $20. Best case, wicked cheap update to your C.
Old Sep 24, 2011 | 02:18 AM
  #36
exoticklr's Avatar
exoticklr is infamous around these parts
thanks
Old Oct 11, 2011 | 02:23 AM
  #37
loveivs's Avatar
loveivs is infamous around these parts
ONLY 19 INTERIOR BULBS WERE FOUND IN MY 957 CTT (NOT INCLUDE 4 * RED REFLECTORS ON THE DOOR & 4 * DOOR TRIM BULBS)
Is that because my car is china spec ? I know for most of car sold in the states, there are orange reflectors on the sides of the front bumper. Never know interior bulb quantity is different too. lol
4 – lower door panel (the downlights that shine on the pavement when the door is open).
2 – Front foot well
1 – Center console (this is interesting, we call it "arm rest" in Australia. My understand is "centre console" is the surface for instrumentation(air-con outlet) and controls(audio/video/nav). I was looking around the PCM, did not find any lighting beside it)
1 – Glove Box
3 – Front overhead light
2 – Rear foot wells (under front seats)
2 – Rear map lights (ceiling above the doors)
2 – Cargo area ceiling (1 bulb)
2 – Rear hatch (facing cargo area)
2 – Rear hatch (facing back when the hatch is open (1 bulb, the red reflector)
Old Nov 4, 2011 | 01:41 PM
  #38
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
I can't get the lenses off for the rear map lights, any tips????
Old Nov 5, 2011 | 01:07 PM
  #39
Mr. C4's Avatar
After having changed the three overhead bulbs and the footwell lights to LEDs the footwell lights are flashing! WTF!?
Old Dec 5, 2011 | 05:15 PM
  #40
mdot's Avatar
mdot is infamous around these parts
this is a known problem with our 955's unfortunately
apparently this was a common problem with the 04-06 models where the contacts would burn out in the switch therefore no power would go to the middle bulb. I searched and searched and came across this fix which helped a lot:
http://www.renntech.org/forums/topic...09#entry129309
The dealership wanted $150 dollars for a new unit to fix the problem, so i decided to do this fix instead and it worked just fine!
Hope that helps
Old Dec 21, 2011 | 09:22 AM
  #41
TenaciousT's Avatar
TenaciousT is infamous around these parts
Excellent thread, thanks. Your link is to bulbs direct from China...are any of the domestic T10 bulbs on Ebay OK? For example:
http://www.ebay.com/itm/LED-WHITE-2X...item2317cc5f27
Also, which bulbs are used for fog lights? The stock ones are very yellow compared to the HID headlight.
Thanks!
Old Feb 17, 2012 | 03:42 PM
  #42
garukun's Avatar
garukun is infamous around these parts
Originally Posted by mikezlee
Roxboxxx, thanks for this. I will try out those bulbs. Hope they are whiter than what I have now. I use LED bulbs for my mirror lights and side markers, and just looks too blue. I'll take pics after I try out your bulbs. Attached are side markers and license plate lights(different bulb). Not really digging the rice blue look right now.
Attachment 144369
Attachment 144370
Also, do the foot lights still dim to your desired brightness?
Do you know what is the bulb type for the license plate?
Old Feb 17, 2012 | 04:29 PM
  #43
is.deleon's Avatar
is.deleon is infamous around these parts
looks nice, i might consider this, thanks for the writeup
Old Feb 21, 2012 | 10:14 PM
  #44
garukun's Avatar
Also, I discovered that my cargo area dome light is not of type T10, it looks something like this, http://www.streetperformance.com/par...063110690.html
But I wasn't sure if this is the right part for 2008 CTT, could someone share some experience?
Old Feb 27, 2012 | 02:26 PM
  #45
garukun's Avatar
I found this website that is pretty useful. It has light bulb types for all porsche models
http://www.modifiedlife.com/2009-por...-size-diagram/
Looks like 6411 is the type of bulb that I could need to get for the cargo dome light.
