Best Replacement Battery?
Old Mar 10, 2011 | 12:03 PM
gr8ful's Avatar
gr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to all
Question Best Replacement Battery?
Having received and given many tips here, I turn to ya'll for advice:
2005 CTT
What's the best replacement battery? Might Optima make a suitable one?
Thanks in Advance,
Old Mar 10, 2011 | 12:21 PM
BlueLodge400's Avatar
BlueLodge400 is infamous around these parts
Optima works great.
2 others I would recommend are:
Odyssey
http://www.odysseybatteries.com/battery/pc1200mjt.htm
and if you want a really lightweight battery I would go with Braille.
http://www.braillebattery.com/
Hope this helps.
Old Mar 10, 2011 | 12:23 PM
gr8ful's Avatar
Any model number on the Optima battery? That's the one I want to use. Thanks.
Old Mar 10, 2011 | 12:41 PM
gr8ful's Avatar
Does the 34R red top fit? It's taller, narrower and the posts stick up and are closer in. How does one mount/fit it??? Have you placed one in a Cayenne and what mods did you make to get it to work???
Old Mar 10, 2011 | 01:12 PM
FastHackem's Avatar
FastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud of
Interstate is what I used and it came with like an 8 year warranty I think.
Old Mar 10, 2011 | 01:42 PM
crowland's Avatar
crowland is infamous around these parts
Take a look at the Odyssey batteries as mentioned above, I am not a fan of Optimas after going through about 6 of them for my boat stereo and they are overpriced for what they are.
Are you running any additional accessories or just looking for a replacement? As far as starting you dont need anything special, just the recommended CCAs.
If you are looking at AGM specific take a look at kinetik, 4xspower and deka - I am assuming you are trying to run a stereo, tvs or other powered equipment. If not, I would just stick with an Interstate. There is no need to complicate things unless you have a reason (just my opinion)
Old Mar 10, 2011 | 02:09 PM
tonka858's Avatar
tonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud of
+1
plus there is 800 number on the battery and if your out of town.they can tell you the nearest dealer.and they melt the date code in the battery.
so even if you don't have a receipt they will be able to warranty it.
Old Mar 10, 2011 | 02:45 PM
I have not used it in a Cayenne before. But other vehicles I have.
Old Mar 11, 2011 | 02:18 AM
quattrotman's Avatar
quattrotman is infamous around these parts
I went with a VW Toureg factory battery. OEM quality without the Porsche sting $$$. I think it was $175
pwdrhound
Sep 16, 2021 02:27 PM
Jul 29, 2019 11:13 AM
DetomasoGTS74
Nov 11, 2015 09:01 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
DSCOFF
Aug 23, 2015 01:22 PM
