Anyone running a 265/65/R18?
Old Aug 17, 2011 | 11:34 AM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
Cool Anyone running a 265/65/R18?
I know the Transsyberia rigs ran this size tire. Looked like they did not use any fender trimming so it "should" fit.
Anyone actually running a set?
Looking to order winter or off road tires for my winter wheels and want something a bit taller.
Old Aug 18, 2011 | 01:04 PM
synk's Avatar
synk is infamous around these parts
I was thinking about doing the same, but you'd have to keep an additional spare in the back since the OEM spare wouldn't match anymore.
Old Aug 18, 2011 | 01:34 PM
Cole's Avatar
Wink
OEM spare?
I have the Bose sub and dual battery CTT, there is no spare! Mine came with a bottle of Porsche "fix a flat" and an onboard compressor.
Old Aug 23, 2013 | 04:39 AM
Saggio's Avatar
Saggio is infamous around these parts
You think I could run a bigger size tire on my 957?
I've got the 2005 18" Turbo Wheels for winter.
Old Aug 23, 2013 | 06:24 AM
Cole's Avatar
Bigger than 265/65/18?
Old Aug 24, 2013 | 08:53 AM
Saggio's Avatar
Yes
Old Aug 24, 2013 | 09:00 AM
Cole's Avatar
Old Aug 24, 2013 | 09:13 AM
Saggio's Avatar
LOL Nooooooooo!
Old Aug 24, 2013 | 11:17 AM
Cole's Avatar
I think the only reasonable next step to a bigger tire is to trim/remove the inner fender liners in the front and probably trim/remove the lower front bumper.
Anything bigger is also at the point of needing a gear ratio swap. Front and rear differentials would need swapped with an S/VR6/Touring Egg, etc depending on what you are starting with and what ratios you need to get.
Old Aug 25, 2013 | 08:28 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Whether you "can" do it, and should do it, are two different things. It's a pretty big jump. You could probably go to 260 60R18 without problem. Why go 265/65? You're better off with full lock-to-lock turning radius and not rubbing under articulation - assuming you're off reading. If not, there's even less reason to chance rubbing and turning problems. If they will clear the fender wells, you will likely need spacers or at least new wheels with less set back to avoid rubbing.
Old Aug 25, 2013 | 08:35 PM
Cole's Avatar
Question
.....and what is your experience with these sizes?
Just curious because I've been running the 265/65/18s for quite awhile now with zero issue. It was also the size used on the Transsyberia race Cayennes, that were not allowed to modify the suspension or body work.
So, just curious what you are basing your info on?
Old Aug 25, 2013 | 09:06 PM
Two things: One disregard as I now see this is 2 years old. Two you're obviously (from your photo) running a modified suspension or have the air suspension set to the highest setting - both of which negate your question and/or the parameters of my answer. Glad it's working out for you either way. I raced these for over 5 years and under full articulation and/or locked steering at speed 265's usually rub too much with a stock suspension.
Old Aug 25, 2013 | 09:07 PM
Cole's Avatar
Raced them where? Pictures?
Old Aug 25, 2013 | 09:22 PM
Mostly California, Nevada & New Mexico. But refer to my last first sentence. 2 year old thread. Additionally, the Transsyberia did not have a stock Cayenne suspension. It was a special suspension dedicated to the production Trans.
Old Aug 25, 2013 | 09:24 PM
Cole's Avatar
Riiiight........I know the thread is old. But I also started it so who cares?
What class, event are you racing these in?
