Help with light bulbs!!
Old Oct 25, 2011 | 04:48 PM
thor7000's Avatar
thor7000 is infamous around these parts
Don't know what's going on, had both cornering lights go out, then noticed the small little blue peanut bulbs out...replaced both cornering lights but couldn't get the blue lights, now the side light on the driver's side is out!!! Could someone please tell me how to get to the bulb?? It's the amber light right by the front wheel well. Looks like the orange lense should just pop out but don't want to try until I can confirm that's how it comes off.
Thanks,
Old Oct 25, 2011 | 06:15 PM
Dennis C's Avatar
I don't have any blue lights on my Cayenne. It sounds like somebody replaced the "peanut" bulbs in your car with blue coated bulbs. They should be fairly easy to access once you have the headlight assembly removed. Have you looked in your owner's manual? It also shows how to get the side marker bulbs out. There's an electronic copy of the manual available on renntech.org for paying members if you don't have your hard copy.
Hal 2000's Avatar
Hal 2000 is just really niceHal 2000 is just really niceHal 2000 is just really niceHal 2000 is just really niceHal 2000 is just really nice
On a 955: Unscrew the fenderwell liner around the light. Turn the wheel to get the screwdriver in better. Take enough screws out to get your hand in and feel where the wire goes to the bulb holder. Rotate, pull and remove the socket. You can see the fog bulbs deep in there too.
Old Oct 26, 2011 | 05:08 AM
thor7000's Avatar
Thanks Hal, much appreciated!! Dennis, they come blue from Porsche, I spoke to Parts and they have them in stock just need to take a drive down to the dealer!!
Old Oct 26, 2011 | 09:49 AM
Dennis C's Avatar
Interesting that they come blue from Porsche! Mine were standard bulbs...
Old Feb 16, 2012 | 09:22 AM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
^ mine came blue from porsche too. does anyone know if these can be replaced with LEDs without causing a warning on the gauge cluster?
Old Feb 17, 2012 | 12:50 PM
TenaciousT's Avatar
TenaciousT is infamous around these parts
I'm in for this answer as well.....including LED for fogs too
Old Feb 17, 2012 | 02:12 PM
myltz400's Avatar
myltz400 is infamous around these parts
http://www.amazon.com/Warning-T10-168-194-LED/dp/B005DHXSSQ
I have the above installed in my 06 S without any errors.
They are brighter, look pretty good around dusk and match the color of the xenons better IMO.
Pull the headlight assembly and open back plate that is held on by two metal wires that rotate out of the way. Use your fingers (pliers if they are short) to gently pull out the long tab that holds the wedge style bulb in place. Replace the bulb with the desired one.
I have been told but cannot confirm that VW dealers have the proper 5w5 bulb alot cheaper than Porsche.
Regular 5w5 bulbs from autoparts counters look dim and yellow to me.
Old Feb 27, 2012 | 01:28 PM
split's Avatar
^ on the 957 i was able to just pull the housing forward and it popped out. i replaced the bulbs with 168 LEDs and I didnt get any errors until today oddly enough, but i'm not even sure if that's what its for. For future reference, one can get 4LED 168 bulbs on ebay for $0.99 shipped that will fit just fine and match the factory HIDs.
AuZZie
Sep 2, 2015 04:26 PM
Airbus Driver
Cayenne 958
Sep 2, 2015 12:50 AM
ppwchiang
Sep 1, 2015 11:22 PM
