Safe to work under CS at highest setting?
Old Jan 27, 2012 | 09:34 AM
GTS Jay's Avatar
GTS Jay has a spectacular aura aboutGTS Jay has a spectacular aura about
If I put my suspension in the highest setting and lock it there is it safe to crawl under the car to work on it? Is there any chance the air suspension could fail and drop the car?
Old Jan 27, 2012 | 10:19 AM
loveivs's Avatar
loveivs is infamous around these parts
if you are asking whether or not there is possibility the air suspension could fail, i would answer you "yes". cause nothing is impossible =)
It really depends what you will be doing underneath the car.
Old Jan 27, 2012 | 10:34 AM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
How hard could it be to put jackstands under the jack points when it's in the highest setting? That way if the suspension did fail, you're not crushed. Jackstands are cheap at Harbor Freight and actually appear to be of reasonable quality.
Old Jan 27, 2012 | 10:35 AM
V10's Avatar
V10
V10 is infamous around these parts
I work on my V10 Touareg and CTT all the time with suspension in highest setting...I live dangerously and don't even lock it
I better play it safe by saying it could be dangerous if all the stars are in alignment and Murphy's heading your way, so don't do it!
Old Jan 27, 2012 | 10:55 AM
GTS Jay's Avatar
I don't think my jack stands will fit under it even at the highest setting but that's a good thought. I'll have to take a look at that...
Old Jan 27, 2012 | 10:56 AM
GTS Jay's Avatar
BTW - I was asking thinking that I would do oil changes that way...
Old Jan 27, 2012 | 11:48 AM
madduc's Avatar
madduc is a jewel in the roughmadduc is a jewel in the roughmadduc is a jewel in the rough
What's your life worth? Lost a friend two years ago from being trapped under his car that fell off the stands. Neighbors heard his cry's for help but couldn't tell where from because of the echo's from nearby house's. Plus his soon to be wife was in the house at the time using a hair drier and couldn't hear him. Didn't crush him, but made it impossible to breath. So get some stands and be safe. Tell someone what you are doing so they know to listen or check on ya once in a while.
Old Jan 27, 2012 | 12:13 PM
GTS Jay's Avatar
Even with jack stands I suppose you're never 100% safe under the car. I think my under car days are over - I'm getting too old for this...
Old Jan 27, 2012 | 01:09 PM
ArcticT's Avatar
ArcticT is infamous around these parts
I would definitely throw a couple of stands under there just in case. It only takes a second and it could literallly be the difference between life and death should some freak accident occur.
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
