Adding TPMS to cayenne?
Old Mar 18, 2012 | 10:36 PM
ciaka's Avatar
If my 2005 CTT does not have tpms, what would I have to do to add it to the car? Besides the obvious addition of tpms modules into each tire, and would it require trip to dealer?
Old Mar 19, 2012 | 08:05 AM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
I am not certain, however, most options are not available to add after the vehicle as been built. From what I understand, Porsche is one of the few manufacturers that will tailor a car's wiring harness to the specific options ordered. This includes running more/less wires, different gauge wires, and altered components. This allows them to be more efficient and save costs.
There are aftermarket options available (see tirerack), however, the install will not appear to be OEM.
Old Mar 19, 2012 | 10:20 AM
ciaka's Avatar
I would have guessed that it may be a sw update, since these are wireless and transmit to collection point which relays info to central display.
Just wondering, since I would really like to have it on the car if possible, without having to go with an aftermarket solution.
My hope was to maybe ensure sw is updated for PCM on my CTT, then the option for tpms woud be visible. At that time, I would buy TPMS sensors and install into tires, and system would pick them up. Is this hope not realistic?
Old Mar 19, 2012 | 11:34 AM
Moderator
Without knowing for sure, I would think you would have an issue with the TPMS ECU that receives the information from the wheels, then relays it back to the cluster. FWIW, the TPMS sensor also monitors the spare tire (if equipped).
I would just call your local Porsche dealer and talk to the service manager to see if you can retrofit this option for sure.
Good luck.
Old Mar 20, 2012 | 12:01 AM
ciaka's Avatar
Tried independent Porsche shop, trying to speak to someone technical there but the *****y receptionist is trying to get in the way...trying to talk technical but not making a good result. Trying to tell me she will find answers for me without knowing what questions I have...lol.
So I wonder is someone here can help with determining what equipment I may be missing for tpms, and what I would need, and then I could talk to shops about install prices or do myself if needed.
Thanks for help in advance.
Old Mar 20, 2012 | 08:28 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
The wiring for it doesn't exist. As mentioned - Porsche (who is NOT unique in this.. BMW has been doing it for decades) doesn't install wiring for anything not ordered with the car, with the exception of dealer aftersale add-ons (like the CD changer on later P!Gs). Even things like the telephone unit in the earlier trucks required major disassembly to add several modules and wiring harnesses, and antennas.
I suspose you could try to do this after the fact - but bet the cost is going to be in the many thousands of dollars range. There are quite acceptable aftermarket TPM system for less then $200 that don't require adding any wiring except power to the display (and a place to put it..) If I felt compelled to always know my tire pressure that's the route I'd go.
Old Mar 21, 2012 | 07:13 AM
ciaka's Avatar
That is what I wanted to see, how feasible it wouold be to do one after the fact.
Suppose there is no wiring, if you assemble all the hardware, and laid the wiring down, is the software there in the MFD to take advantage of this, or would it have to be enabled via some sw update to the mfd? As of now, I do not see an option to view tpms settings, and just wonder how this plays into the whole deal.
If I went the aftermarket way, any suggestions for some units that do look decent and work well?
Thanks again.
Old Mar 21, 2012 | 10:24 PM
It's not a "suppose" - there is no wiring. How are you going to get into the computer to enable it? You *might* be able to do that with the Duramatic Pro series diagnostics program, but that isn't an inexpensive program.
As far as aftermarket - I'm using one from the UK on my BMW bike, they also make car ones, and sell those in the US.. I'll have to see if I can track them down. Only downside - the display has an illuminated blue background, orange would be better (on the BMW also..)
Old Mar 22, 2012 | 12:52 AM
Bigbuzuki's Avatar
Bigbuzuki is infamous around these parts
If you don't have option code I7K4 then you don't have the factory fitted TPMS.
You would have to install wheel well antennae, brackets for the antennae, associated wiring from each of the antennae to the control unit, a tpms control unit, wiring from the control unit to the network, wheel transducers, software programming of the system etc.
Not impossible but probably not cost effective as the bill would run into thousands of dollars.
Old Mar 22, 2012 | 07:50 AM
ciaka's Avatar
Thanks for the input.
I would have no problem with getting the hardare, mounting, and wiring. The hardest part I see is the software to enable, which makes me kind of lose interest in this project.
Looks like I will see about after market solutions for TPMS.
Thanks a lot for all your feedback.
Old Mar 22, 2012 | 10:44 AM
GTS Jay's Avatar
GTS Jay has a spectacular aura aboutGTS Jay has a spectacular aura about
I would think the software would be the least of your problems. If you can get the hardware in I think the dealer can program it...
Old Mar 22, 2012 | 12:51 PM
Mobiletron - that's the brand I'm using on my 2 wheeled BMW.. I believe they do sell the auto TPMS in the US..
Here is a link to one that would probably work: http://www.mobiletron.com.tw/b_eng_p...031&Pd_Id=3581
They seem to have two distributors in the US: http://www.mobiletron.com.tw/b_eng_c...us.asp?Cu_Id=4
These guys list is on their website: http://www.regitar.com/tpmslist.aspx?Category=4 Wheel - No price I can see.. but worth an email I think.
ModBargains
Maserati Vendor Classifieds
Oct 13, 2015 03:46 PM
ModBargains
BMW Vendor Classifieds
ModBargains
Audi Vendor Classifieds
Oct 13, 2015 03:45 PM
ModBargains
ModBargains
Oct 13, 2015 03:43 PM
