Recommended tool set for 03-06 CTT
Old Mar 20, 2012 | 01:06 AM
ciaka's Avatar
Can you help and give me your view of what one having a 1st Gen CTT should have in their tool box?
Tool name, maybe sizes, anything that would give a good list of 'good to have' for the DIY people.
This way, I won't have to waste time running to stores when doing work/maintenance.
Help is greatly appreciated.
Old Mar 20, 2012 | 07:32 AM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
Well, like any Porsche there are some special tools for certain projects. Most of which you will never need.
I've been collection tools for 30 years.
Here is what you will probably really need.
-set of metric sockets with gear drive and hollow centers.(gear wrench or similar)
-set of metric wrenches, may as well get the ratcheting kind too.
-hose clamp wrench is handy for the German cars.
-couple of basic screwdrivers
-set of triple squares to access the drivers seat battery.
-good floor jack and jack stands
-Durametric would be nice, but not really needed. I have the vagcom one for my Audis and it has been handy.
Other than that, not much really. I've done my coolant pipes, both batteries, driveshaft rebuild, control arms, chip, BPVs, headlight painting and polishing, fm modulator, and a bunch if little misc stuff and never used much more than the basic hand tools.
And quite honestly, I've rebuilt my other Porsches with 95% basic hand tool use. There is the occasional special Porsche tool that someone local usually has, a tool I can "rent for free" from the local auto parts store (they all do this), or the random bigger tool like my welder.
Old Mar 20, 2012 | 07:42 AM
Cole's Avatar
Here is a perfect example of what I'm talking about.
This picture was from my CTTS control arm install. 99% of the tools used here, as you can see on the floor, we're basic hand tools and a 20year old $20 jack. (and jack stands that is kind hiding behind the jack and brake in this picture)
Granted, in the background there is a compressor and a small pile of special tools, but you don't need any of that. I didn't use it on this project at all.
The only small exception on this project is the "pickle fork" laying on the ground for separating the blo joints. Easy enough to find at any auto parts store if/when you do a job like this.
Also, don't run out and buy $1,000 of tools at the pro shop. Honestly, go to Harbor Freight. Their quality has come up dramatically over the past 10 years, they warranty the stuff and it's s fraction of the price of the name brand stuff. We have bought lots of HF stuff to use as "trail tools" for Rockcrawlers and found that they have some great stuff. (you have a tendency to lose or break stuff repairing a crawler out on the trail)
Old Mar 20, 2012 | 08:22 AM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
I would add to that:
Set of inverted torx bits
Cable-operated hose clamp pliers - for those impossible to reach hose clamps
Old Mar 21, 2012 | 07:18 AM
ciaka's Avatar
So what we got is:
-Durametric (nice to have), but not really needed
-inverted torx bit set
-hose clamp pliers (cable operated or otherwise)
any more? I have majority of this stuff, but wanted to see how those who have already worked on the cars view what they found useful. And yes, I do not plan to rush out to get stuff. I tend to acquire as I need, but will be doing some maintenance stuff on the CTT (prevetative care), and wanted some good pointers.
Old Mar 31, 2012 | 12:08 AM
MiniSuperDuke's Avatar
MiniSuperDuke is infamous around these parts
How about recommendation for a manual........Bentleys?
Old Apr 1, 2012 | 08:31 PM
ciaka's Avatar
what about torx screwdriver set?
I have been seeing references to it a lot and see a bunch of screws in the car of this kind.
Should they be the kind that has a hole in the middle, or as long as it is the star (witout a hole woul do?).
Also, what renage of torx tools would you recommend for cayenne? Thanks.
Old Apr 1, 2012 | 09:56 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Let us know if you find one. The only one I've seen is the factory manual illegally copied to PDFs - with faults in it - and it's actually fairly horrible and counts on a factory trained mechanic using it. It's also illegal - but I think I mentioned that.
km90265
Aug 31, 2015 11:00 AM
oddjob142
Aug 24, 2015 05:49 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
silver86
Cayenne 958
Aug 21, 2015 03:08 PM
cab83_750
Aug 19, 2015 12:37 PM
