May need battery
Old Jan 6, 2013 | 03:16 PM
ciaka's Avatar
May need battery
Went on vacation for a week and a half. After returning, the CTT was dead (engine did not want to turn over), but waited a bit, turned everything else off and it did start. Drive for a while and it seemed OK. About week later (today), tried start again and this time nothing. Won't turn over. Appears as discharged battery.
My questions are:
1. Is the under seat batt, the main batt for starting (replacing)?
2. Where is other batt?
3. Would it be wiser to try trickle charge it before determine it is bad? Would need to buy charger first though.
4. What is a decent replacement batt, and from where, so I don't spend 300 bucks for it?
Overall, looking for advice on plan of action on this (to me appears replace it, butt wanted second opinion from you fine folks).
Old Jan 6, 2013 | 05:26 PM
the head's Avatar
the head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the rough
Just replaced mine under the driver's seat with an Autozone 8 yr battery. It was about $130. I only have the one battery.
Old Jan 6, 2013 | 08:45 PM
ciaka's Avatar
Which one did you get from autozone? Platinum, gold or regular duralast. The gold is the one with 8 yr warranty plhs tax.
http://www.autozone.com/autozone/par...mString=search
Old Jan 6, 2013 | 11:06 PM
glock439's Avatar
glock439 is infamous around these parts
I paid $180 for a factory one at a dealership in Massachusetts. The autozone battery is smaller. Goodluck
Old Jan 7, 2013 | 12:13 AM
pcst's Avatar
pcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the rough
how about optima?
Old Jan 7, 2013 | 09:51 AM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
Originally Posted by pcst
how about optima?
I've used Optimas a lot and have come to this conclusion.
For an application that needs tip over protection (Jeep or Racecar) or that neds the fast recovery ability (Jeep with a winch) it is a great battery. For all other normal car uses it is simply too expensive and gives no real benefit. My Optimas have not lasted any longer, in fact they all died fiaster than normal batteries. They have not stayed charged longer when a vehicle sits.
They do change to full capacity faster which is great for a vehicle running a heavy electrical drain item like an electric winch. Or in an application where you need to mount it upside down, on its side, or where it may end up in those positions.
Otherwise for a normal factory battery replacement it's squally a BIG savings to keep a stock type unit.
Old Jan 7, 2013 | 04:07 PM
slant83's Avatar
slant83 has a spectacular aura aboutslant83 has a spectacular aura aboutslant83 has a spectacular aura about
Ditto here. Be sure to get the 10 mm triple square bit (sears) for the seat bolts to make you life easy. Took about 45 min beginning to end
Old Jan 8, 2013 | 08:15 AM
ciaka's Avatar
Got it replaced yesterday.
Bought the Autozone Gold series batt.
Cost including tax and after core replce was just around $150.
Easy to replace. Another member wrote a good battery replace thread HERE.
Some additional observations:
- after replace of battery, got a host of errors including lights on cluster.
- Used Duramatric to clear all errors.
- Since some error lights on cluster persisted after clear (stayed on), I drove the car, and as soon as I started driving, errors got cleared up.
Thanks. All is fine now.
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
WheelsupZR1
Oct 20, 2015 08:36 PM
G ///Mcgregor K
Sep 30, 2015 01:46 PM
