How to open rear door from outside
Old Feb 19, 2016 | 02:52 AM
tiennd's Avatar
tiennd is infamous around these parts
Question How to open rear door from outside
Hello,
I have several questions:
1. For some setting change or some reason I don't know, now I can not open my rear hatch door from outside while the key is in ignition and engine is running and I pushed the unlock all doors button at driver door.
I still can open rear door using the button at driver door or by taking out the key and push the rear door open button on the key.
2. When engine is running, if I open the driver door, there is some beep beep warning alert. Now there is no longer beep beep when I open driver door while engine is running. The same if I keep the signal light on and take out the key, now no more beep beep. Does anyone know why?
3. Normally my driver seat auto move back few centimeter when I take out the key and open driver door to get out. Now it no longer moves backward. Does anyone know why?
Thank you for your help
Old Feb 19, 2016 | 10:37 PM
jdubbya's Avatar
jdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to behold
Originally Posted by tiennd
Hello,
I'm not sure about the first two although #2 I just learned recently that mine would beep if I turned the car off with the turn signal stalk still on (either up or down).
For the rear hatch I have entry and drive and I'm able to open the rear hatch even with the car running. Not sure if the entry and drive makes a difference or not though.
As for #3, at least on my '05 955, there is a small button on the right side of the steering column. You push this button to turn "easy exit" on or off.
Old Feb 20, 2016 | 05:56 PM
Porscheman33's Avatar
Porscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud of
Try going threw the command Settings, or try to go and reset...
e8_pack
May 17, 2016 10:43 AM
acs370
Feb 9, 2016 06:19 AM
MBA
Feb 4, 2016 02:23 AM
skipath
Cayenne 958
Feb 1, 2016 07:43 AM
skidmarkz
Jan 26, 2016 08:46 AM
