Bypass pipe only or muffler too
Old Mar 23, 2007 | 09:19 AM
das_beast's Avatar
das_beast is infamous around these parts
Do I need to replace the muffler if I do the Fabspeed Cat bypass pipe? I don't want the car to get too loud at highway speeds as I use this car for traveling. Also would intake help if I do the bypass pipes.
Old Mar 23, 2007 | 10:55 AM
JAY@BRANDYWINE's Avatar
JAY@BRANDYWINE is infamous around these parts
the bypass pipes are great, they are not loud at all with the stock muffler and you pick up good power and great sound, on a cayenne S a nice set up is the GIAC software, Fabspeed cat bypass, and EVO intakes IMO.
Old Mar 23, 2007 | 10:56 AM
MeanMachine's Avatar
You dont need to replace the muffler, you can just get the bypass pipes alone. However when installed the bypass pipes sound quiet raspy withthout the Fabspeed mufflers. I have them installed for 1 1/2 and no problems so far.
Old Mar 23, 2007 | 11:40 AM
das_beast's Avatar
That's the setup I am thinking of, with the V-Flow intake.
Old Mar 23, 2007 | 11:45 AM
yep EVO V-Flow is the way to go, thats a great system, go for it, we have had great sucess with it so far.
Old Mar 23, 2007 | 03:35 PM
BD 997's Avatar
BD 997 is infamous around these parts
will the bypass fit in the MY08 Cayenne Turbo?
Old Mar 23, 2007 | 03:41 PM
that im not sure about, ill have to check with the guys at Fabspeed, i dont think so thought
Old Mar 26, 2007 | 11:43 AM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
I got the bypass pipes is my wifes Cayenne S and are great!! better sound ... no loud...better gas cons....a bit more power.. everything is true
Old Mar 26, 2007 | 01:51 PM
BD 997's Avatar
cool... thanks Jay
Old Mar 27, 2007 | 07:51 AM
das_beast's Avatar
Thanks for the responses guys. Someone has said to get the GIAC download also to prevent check engine light. Is this necessary, and does it void the warranty?
Old Mar 27, 2007 | 09:24 AM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
Not necessary, no check engine light even withtout ECU flash..
Old Mar 27, 2007 | 09:28 AM
Alex is correct, but the flash is a nice compliment to the intake and bypass pipes
Old Mar 28, 2007 | 08:06 AM
BobbySpeed's Avatar
BobbySpeed is infamous around these partsBobbySpeed is infamous around these parts
No CEL with my bypass pipe either- and it makes a nice difference in responsiveness.
Old Mar 28, 2007 | 08:35 AM
BD 997's Avatar
I wonder if on the CTT it sounds deeper/throatier...?
Old Mar 28, 2007 | 08:48 AM
UtterNirvana's Avatar
UtterNirvana is infamous around these parts
It sure does! I think this with the evo intakes is plenty in terms of sound change. The two together was limit fmy wife was able to take.
