How much different will the ride height be for...
Old Apr 13, 2004 | 07:34 AM
dmerc's Avatar
dmerc is infamous around these parts
A Cayenne S with 22's and a 30MM lowering spring vs. stock?
I want to put Tech Art 22's on my Cayenne with their lowering springs and am curious how the height will change from where it is now. About the same? Lower?
Old Apr 13, 2004 | 07:58 AM
TCM's Avatar
TCM
TCM is infamous around these parts
dmerc:
The car will definately be lower. The TechArt springs definately drop the car more then 30mm and help improve handling, and looks of the car without interfearing with the ride too badly. The 22 inch Formulas should have lower profile tires on them to compensate for the larger diameter in the wheel size. So basically, your car will be as low as it would be by just putting on TechArt springs and leaving the stock wheels. The new wheels should not change the overall diameter of the wheel/tire combo. Hope this helps.
Old Apr 13, 2004 | 09:23 AM
DEETZ's Avatar
GO 6SPEED!
DEETZ is infamous around these parts
Ride height? Check my car under my siggy, I use the Techart spring, it says that it lowers the car by 30mm, thats BS, its actually more than that, about 40mm. Ask TCM, he installed it for me.
Its a good investment, handles better and looks better ^^
Old Apr 14, 2004 | 10:02 AM
dmerc's Avatar
So you guys think that if I switch over to the 22's and not change the springs, the ride height will be the same?
I like the ride height the way it is but would like to see the car with the 22's on first because then I might want to drop it.
Old Apr 14, 2004 | 10:12 AM
DEETZ's Avatar
GO 6SPEED!
the ride height will be the same because the overall diameter is about the same. Why don't you get the 22" put it on and if you don't like it, get the spring. It will look awesome with the spring.
Honestly, it won't look good if you get the 22" without lowering it
Old Apr 14, 2004 | 10:17 AM
dmerc's Avatar
Deetz: I think you're going to be right!!
Anyone have any reccomendations on where I can get a good deal on those 22's?
Old Apr 14, 2004 | 10:25 AM
DEETZ's Avatar
GO 6SPEED!
I was in the market for 22" Techart few months ago but I decided to get something else.
I did alot of research and asked for prices from different company and I found out that Arling from Lucent gave me the best deal and he has the best service too!
Check this out: Arling/Lucent, great service as usual you won't believe this
either you PM him (20C4S) or email him
good luck n dont forget to post pictures
Old Apr 14, 2004 | 01:31 PM
jamy85's Avatar
Boobie Stars
jamy85 is infamous around these parts
I recommend Arling too..... He offered me the lowest prices
Sales@RSW
Lamborghini
Oct 1, 2015 02:01 PM
Sep 28, 2015 02:19 PM
