2011 Cayenne A/C Question
Old Jun 7, 2011 | 05:29 AM
AJRDU's Avatar
AJRDU is infamous around these parts
It is HOT and HUMID here in NC. I've owned several German/European cars and this is the first one that has given me this problem. Normally I just set the temp in the car to 72 and let it ride. I have to set it to 65 in automode for it to blow hard enough to keep the car cool otherwise it slows the fan and warms the air up. I went into the vehicle settings and set airflow to strong and turned off the ventilation panel. Both of these helped, but i still have to keep it turned way down. I'm thinking it's a temperature sensor issue as the air gets very cold when set down to 65, but it warms up when you raise the temperature. It's almost as if it thinks it's cooler inside the car than it really is. Anyone else having this problem? There is a fella in Kansas on one of the other forums who reports the same thing.
Old Jun 7, 2011 | 06:30 AM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
Take er in just to see.
No issues with mine. Auto works fine for all 4 zones.
Old Jun 7, 2011 | 03:07 PM
GBXSport's Avatar
GBXSport has a spectacular aura aboutGBXSport has a spectacular aura about
I've been having this same issue. Setting the ac at any temp Above 66, the air blows out lukewarm. Very frustrating. Need to take it in when I have time.
Old Jun 7, 2011 | 04:50 PM
dochusar's Avatar
dochusar is infamous around these parts
I have had a similar problem with the 2005 in that you had to cool down the vehicle for a long time. This is with the standard and not 4 zone air condition. I need to keep the temp down to 65 in order to cool the car. But after about a 1/2 hour, it cools nicely above 65. There is a temperature sensor near the driver vent may be the culprit.
Will take it in for a visit to service when I have the time.
Old Jun 8, 2011 | 12:33 PM
djay's Avatar
djay is infamous around these parts
Same issue here. I have to keep it at 66 and seat vents to highest to be cool and it's really loud(both vents and the seat fan). It's only getting up to 80's here and I'm wondering what I'm going to do once real summer comes around.
Old Jun 8, 2011 | 12:40 PM
Jace's Avatar
Might take them to dealership just to get them looked at.
Today it is 95 I have panoramic and set it to 72 auto and it was on level 2-3 blower speed and nice an cool.
Old Jun 8, 2011 | 04:58 PM
slw23's Avatar
slw23 is infamous around these parts
Jace- do you ever notice the air blows out a little warmer at times? My AC doesn't seem to have a problem cooling the car (gets plenty cool), just on occasion, warmer air will blow out for a couple mins, and then it reverts back to cool air. Thx.
Old Jun 8, 2011 | 05:33 PM
Aperture776's Avatar
Aperture776 is infamous around these parts
Does this happen in AUTO mode. I'm assuming that it blows out warmer air because the AC compressor shuts down to maintain the desired temperature setting just like how a home AC unit works by shutting it off when the desired temp setting is reached.
Old Jun 8, 2011 | 06:10 PM
slw23's Avatar
I've noticed it in AUTO mode in the past, but today, the air was warm for a couple mins when I manually set the temp and fan. It went back to blowing cool air for the rest of my 20 min drive after those couple mins.
My two previous cars would only adjust the level of the fan, not the temp, when using Auto mode, but you could be on to something about the AC compressor cycling on/off.
Old Jun 8, 2011 | 07:23 PM
Jace's Avatar
To be honest I haven't noticed a variance in the temp hen in auto just a change in fan speed, but I will try and pay attention tomorrow and the rest of the week and report back.
Old Jun 8, 2011 | 07:53 PM
w00tPORSCHE's Avatar
w00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond repute
Slw23 i have also had the same happen to me and my wife and I looked at each other going what was that ....
Old Jun 8, 2011 | 07:57 PM
SLATETT's Avatar
SLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to behold
whoa - when I put my '09 CTTS at 72 - I freeze.
Old Jun 8, 2011 | 11:07 PM
slw23's Avatar
Sorry to hear you're experiencing the same thing, seems like we're not alone. And it's not an issue with the AC not getting cold enough, it's just the random min or so blowing warm air. Wonder if this is how it's supposed to work like Aperture mentioned with the compressor cycling off?
Old Jun 9, 2011 | 08:17 AM
Jace's Avatar
Makes perfect sense if so. Compressor turns off for a few normal air recirculates then it turns back on when in auto..
Doesn't hurt to take er in and get it looked at real quick...
Old Jun 9, 2011 | 01:59 PM
mto's Avatar
mto
mto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud of
About 100 degrees and sunny today, A/C works better than my 997.
