Does anyone know how to get the time to show up on the PCM?
Old Jun 21, 2011 | 11:33 PM
2011PorscheCaye's Avatar
2011PorscheCaye is a jewel in the rough2011PorscheCaye is a jewel in the rough2011PorscheCaye is a jewel in the rough2011PorscheCaye is a jewel in the rough
I can only get the temperature in the bottom right corner. i don't like to have to change this on the multi function or hit car just to see the time...
Old Jun 22, 2011 | 01:22 AM
slw23's Avatar
slw23 is infamous around these parts
I don't think there is a way to get it to permanently show on the PCM. You can set it up on the multi-function display on the dash on the bottom line...
Old Jul 14, 2011 | 10:40 AM
Ptarded's Avatar
Ptarded is a jewel in the roughPtarded is a jewel in the roughPtarded is a jewel in the rough
It's under the PCM options. Hit either info or car can't remember then option button then go into PCM settings and look for it under display you can then decide either time or temp.
Old Jul 15, 2011 | 04:04 AM
AJRDU's Avatar
AJRDU is infamous around these parts
+1--at least on mine. You can make it show on the car menu as the first screen next to the compass there, but I can't make it show in the place of the temperature in the bottom right corner.
Old Jul 15, 2011 | 10:57 PM
Ptarded's Avatar
Post
Okay just got home and I'm sitting in my cayenne. From my PCM I pushed the car button, then the option button, select the SET PCM system option, then select the Display PCM option, then select the Footer (temp./time) option. Choose wether you want time or temp then back out. You are all set. Hope that clarifies it for everyone. If you still can't find it perhaps you need an update. Good luck.
Old Jul 15, 2011 | 11:09 PM
slw23's Avatar
Do u know what software version you have? When was your car built? I definitely don't have that option, late Nov build, so it must have been an update. I remember reading many complaints from the early 2011 adopters because of the lack of time display on the PCM. I wonder if dealers charge for software updates? Not a big deal to me at this point, I got used to looking at the small display by the speedometer. Thanks for sharing!
Old Jul 16, 2011 | 06:42 PM
JCBH's Avatar
JCBH is a splendid one to beholdJCBH is a splendid one to beholdJCBH is a splendid one to beholdJCBH is a splendid one to beholdJCBH is a splendid one to beholdJCBH is a splendid one to beholdJCBH is a splendid one to behold
I, too, don't have that option, and our CTT is a November build, I believe...let us know when you can what software version you have...thanks, and great tip!
Old Jul 16, 2011 | 09:16 PM
Truonk's Avatar
Truonk is infamous around these parts
Mine was built end of May and doesn't have it. I think he has a 2012.
Old Jul 18, 2011 | 10:52 PM
Ptarded's Avatar
Talking
Correct I do have a 2012 just landed about 2 weeks ago so I'm sure it has the latest update. Might need to make the trek to the dealer for an update if it's worth it to you. Good luck guys.
Old Jul 20, 2011 | 11:26 PM
Let me know if anyone gets their software updated.. I'll probably request it the next time I'm at the dealer. Probably won't be for awhile though
Old Jul 22, 2011 | 09:32 AM
GBXSport's Avatar
GBXSport has a spectacular aura aboutGBXSport has a spectacular aura about
according to the dealer, i have the most updated software and i dont see that option. Must be a 2012 thing. I hope we get an update soon for this.
Old Jul 23, 2011 | 11:13 AM
DonS's Avatar
DonS is infamous around these parts
The lack of a full time clock on the 2011 is one of my main issues with the UI for this car. I had the dealer check to see there is a "hidden" menu in the PCM to display the time instead of the temp. No luck.
That along with the inability to remember the radio was muted when turning the car off (radio comes back on when you start the car every time). I really dislike this.
Is the radio bug fixed in the 2012? I wonder what else has been changed in the 2012 PCM and also why is it so hard to get updates/patches from the dealer.
Regards
Old Oct 8, 2011 | 09:42 AM
TGED's Avatar
TGED is infamous around these parts
I am also disappointed by not able to display the time on my 2011 PCM. However, if Porsche considers this as a product improvement, then they are not obligated to retrofit it to previous owners even though this may involve something as simple as a software/firmware update. I hope if more owners bring this to Porsche's attention, they may think otherwise.
Old Oct 8, 2011 | 11:34 AM
VinceV's Avatar
VinceV has a spectacular aura aboutVinceV has a spectacular aura about
Have it on my 2012 bought last month.
Old Oct 9, 2011 | 04:12 PM
Bill P.'s Avatar
Bill P. is infamous around these parts
Mine was built one year ago. I show the time and temp at the bottom of every screen except the map, FWIW.
