No need to order Compass Display just for looks...
I ordered the dash insert from suncoast. The opening for the clock is about 2.5 inches. I could only find 1 clock that is 2 5/8 an inch. There is hundreds that are 2 1/16 but they are too small. I am 50/50 on the quality and if I should have it installed. What do you think?
https://picasaweb.google.com/1134421...40012132847858
You probably do need proper software for the compass to work. Each PCM unit is factory coded specifically according to your VIN, therefore it only works with whatever equipment the vehicle is ordered with.
my build on my 12 is 04/12 and has the clock as standard, i dont think its a bew feature on the 13's. one thing i dislike about it is that the second hand always ticks and i cant seem to figure out a way to make it stationary.
Can you elaborate on that menu entry - thanks!
I found everything I needed. I ordered the dash peace from suncoast. I used a 2 5/8 to 2 1/16 adapter to install a 2 1/16 clock I had made. I think the install looks really clean. The adapter is black metal. The clock has a metal bezel and is backlit. I am pretty happy with it over all. It took a high end car audio shop about 3 hours for the install. It was hard to find a wire to trigger the backlight numbers. It looks great at night. The numbers and clock hands match the dash also.
https://picasaweb.google.com/1134421...44873470509522
compass for cayenne S 958
Dear friends
i'm from France and i bought the compass on ebay (from Florida) and now i need to buy the cable to connect it to the PCM. can you help me to find the N/S of this cable ?
Best regards to all
Best regards to all
PelicanParts.com
Aug 26, 2015 04:25 PM
PelicanParts.com
Aug 26, 2015 04:24 PM
