Snapped Camshaft Adjuster Bolt = Engine & Brake Hydraulics Failure ?
Old Aug 12, 2016 | 12:34 PM
  #181
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Hmmm... seems another complaint has been registered with NHTSA. Dunno why NHTSA removes all paragraph breaks and capitalizes everything:
http://www-odi.nhtsa.dot.gov/owners/...od_ids=1433775
Look under the complaints tab..
Old Aug 12, 2016 | 01:31 PM
  #182
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
https://www.6speedonline.com/forums/panamera/391141-panamera-2011-3-6-engine.html
Old Aug 12, 2016 | 10:44 PM
  #183
A "cracked" camshaft is NOT the same problem. And it sounds like a one-off.
Old Aug 18, 2016 | 08:36 PM
  #184
I've heard from a reputable source that the V6 may suffer from the same sort of failure. Perhaps the same vendor made their Variocam adjuster?
Old Aug 21, 2016 | 02:36 PM
  #185
Accordinv to my dealer they only replaced the camshafts bolts for NA engines .
Old Aug 21, 2016 | 11:14 PM
  #186
Your dealer is misinformed or lying to you. Not a surprise. WC-22 covers both NA and Turbo engines, Cayenne and Panamera.
Look at: https://www.6speedonline.com/forums/...ml#post4524693
Old Aug 22, 2016 | 01:40 PM
  #187
Was at the dealers today for a new rear wiper (car wash paying for it..) and got to chatting with one of the service-writers about WC-22. He again looked it up vs my VIN# and said my CTT wasn't included in the WC. Nothing new there..
So I asked him to give me an estimate on the cost to me - to have them do it. Surprisingly, it wasn't awful.
Parts came to $1507
Labor came to: $1080 (8 hours)
So total around $2600.
I may tell them to order the parts.. prices on the parts reflect a reasonable discount off "List" (the camshaft adjusters - $567/each)
Figure if/when NHTSA/DOT comes out with the recall it will require Porsche to reimburse people who had the work done already, so it's basically going to be a wash, eventually, hopefully.
SWMBO wants to do another coast-2-coast-2-coast trip (this would make #5 for me - 3 by car so far, and 1 by motorcycle), and I don't want to worry about the thing barfing the engine someplace in Bummfook North Dakota (or "Dakota" as they want to change it to - it sounds less cold that way..)
Thinking how to broach this to her..
Old Aug 22, 2016 | 07:05 PM
  #188
Procera's Avatar
Procera is infamous around these parts
I was given a worse case estimate $4500 when the camshaft bolts on my Panamera 4S went south. Hard to compare these 2 estimates though.
Parts came to $1507
Old Aug 22, 2016 | 10:07 PM
  #189
Yours undoubtedly included fixing bent valves and such..
Old Aug 24, 2016 | 11:54 AM
  #190
Mcheah's Avatar
Mcheah is infamous around these parts
Hi guys, I work for an attorney that litigates auto defect cases (individual and class actions) and I heard about this defect from a client of ours. I can't say if this particular defect is class action material or not but if you've had this issue I would highly recommend filing a complaint with NHTSA if you're in the USA (https://www-odi.nhtsa.dot.gov/VehicleComplaint/), and let me know if you find out anything more regarding Porsche's knowledge of the bolt defect. I wrote up an article that quickly goes over everything I heard firsthand and from these forums (http://www.bestattorney.com/blog/por...comes-to-light) but i'm sure as this happens to more people there will be more to write about in the future.
Old Aug 26, 2016 | 08:58 AM
  #191
sterz's Avatar
sterz is infamous around these parts
great article. i wonder if PCNA would come across it and what they might say.
what i find irritating is that the WC22 doesn't state the months of production for the 3,509 cars impacted by the issue. my car is a 2012 CTT with a production date of 9/2011 and has the part number which the WC22 says to replace. but my vin is not included in the wc22 bulletin.....
Old Aug 26, 2016 | 09:13 AM
  #192
Hi - nice article - mostly correct - but when I tried to post a comment, that wasn't allowed due to your firewall (seems odd to have a comment entry form, then forbid entering comments.. but..) Anyway - here is what my comment was:
Originally Posted by Me in Comment Form
This issue isn't limited to the /S model - it is a problem with any of the V8 engines made during that time, including the Turbo. WC-22 has specific references to the Turbo engine. Since the same engines were used on the Panamera - the same issues are happening there.
There apparently is also a similar defect in the V6 engine cars from the same time frame, but I haven't seen enough detail on these to be able to say it's the identical defect.
One other point - the WC-22 campaign calls for the replacement as a unit of the Variocam adjusting units (aka: Camshaft Adjusters) which now come with steel bolts in place of the aluminum ones. Cost per is list $688.99/each. Two of them must be replaced. There is an additional ~$400 worth of parts called for replacement in WC-22, mostly mounting bolts and valve cover gaskets.
BTW - there have been several additional complaints registered with the NHTSA website. Thanks to the people who did so. Anyone who has experienced the failure would be doing the other Cayenne owners a big favor by filling in the form on the NHTSA website.
Old Aug 26, 2016 | 09:21 AM
  #193
Neither is mine - but mine has the aluminum bolts. I would say any V8 with the aluminum bolts should get them replaced just based on the number of failures we've seen reported of other Cayennes/Panameras that weren't included in the WC-22 VIN range.
Old Sep 1, 2016 | 09:36 AM
  #194
Mine is in getting the camshaft adjusters replaced today.. WC-22. It is coming out of my pocket.
Bad part is - I gotta pay for it. Good part is - I get the old parts back, so I can take a looksee at the bolts and see if they could be replaced in-situ or not (my guess is - not - probably in there with red Loctite..)
Have a Q3 Audi loaner. It's certainly not a Cayenne. Feels rubbery. Interior is spartan and mostly black plastic. I guess it's good on mileage.
Will report back when I get the P!G back..
Old Sep 1, 2016 | 10:57 AM
  #195
sterz's Avatar
Good stuff, interested to hear your thoughts on the bolts once you get a chance to inspect them.
I ended up spending the money on a warranty. I'll probably do the bolts if they don't go while under the warranty or if I decide to keep the car.
