Snapped Camshaft Adjuster Bolt = Engine & Brake Hydraulics Failure ?
Old Mar 10, 2017 | 05:28 PM
  #361
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Originally Posted by porschecayenne92
the coalant pipes have been blowing from different porsche models since 2000 and porsche still sont give a damn . Other than 2 accurators and bolts (1100$) for both , what else do you need ?
Actually a LOT of bolts - most of the bolts on the engine are one-time-use aluminum security bolts. Including the valve cover bolts. You also need valve cover gasket and spark-plug-well gaskets. Total on parts - even from a discount parts dealer is about $1,500-1,600. I believe you also are going to replace the diamond-washer that keeps the actuator fixed on the end of the camshaft. Having a set of camshaft timing tools also will make the probability of a successful job much higher.
Old Mar 13, 2017 | 02:13 PM
  #362
cofred's Avatar
cofred is infamous around these parts
I just had mine replaced on my own dime at my dealer and the parts came to $1817.92.
HTH,
Heath
'12 Cayenne S
Old Mar 13, 2017 | 03:18 PM
  #363
kozzimo55's Avatar
kozzimo55 is infamous around these parts
HTH,
Heath
'12 Cayenne S
I am curious, did they charge 6.5 hrs of labor?
Old Mar 13, 2017 | 04:28 PM
  #364
cofred's Avatar
It looks like they charged 8, but because that was more than the SA quoted, they discounted it for me, so I can't tell for sure. The SA quoted $2400-$2600 and it ended up being $2697 after adjustments.
Old Mar 13, 2017 | 05:23 PM
  #365
That sounds about right. Looks like they charged you list for the parts (a PCA discount is a handy thing to have - and it easily pays for a years dues the first time you use it on something like this) and gave you a deal on labor. Mine was about $2,600.
I do see people getting silly quotes from greedy dealerships. I can recommend Porsche of Monmouth, Rt 36, West Long Branch NJ - as not being greedy. Perhaps a list of dealerships that have done the job at a reasonable price would be a good way to repay the dealership for not being greedy.
Yours was done at?
Old Mar 13, 2017 | 06:57 PM
  #366
cofred's Avatar
Park Place Porsche, Dallas, TX
Old Mar 14, 2017 | 04:56 AM
  #367
Tom M's Avatar
Tom M is infamous around these partsTom M is infamous around these parts
List price on the parts from Sunset Porsche (either the WC-22 kit or priced individually) is just under $1500 based on written quotes from them but their regular discounted price is just under $1200. I know my local dealer has a ~25% markup over MSRP as they're the only player in town and that kind of ripoff puts the prices in the $1800 range for just the parts.
Old Mar 14, 2017 | 08:46 AM
  #368
sjg1138's Avatar
sjg1138 is infamous around these partssjg1138 is infamous around these parts
My local dealer (NorCal) gave me the below quote:
$3,585 total for the entire job (part/labor/etc).
"The parts needed are the same as listed in the WC22 service action plus two additional solenoids ($256.06 X 2). We have found that the solenoids can be problematic. We replace them because they are mounted next to the cam actuators."
Parts total - $2078.32
Tax - $176.66
Labor - $1,330
Old Mar 14, 2017 | 11:57 AM
  #369
kozzimo55's Avatar
Tax - $176.66
Labor - $1,330
Do you have a part number on the solenoids? Is this an upsell or have other confirmed having issues with these solenoids?
Old Mar 14, 2017 | 12:54 PM
  #370
sjg1138's Avatar
I don't have a part number but I do have a picture (provided by the dealer). They very well could be upselling.
Old Mar 14, 2017 | 03:37 PM
  #371
So far I haven't heard of anyone having a problem with the solenoids. Zilch. Sounds like an upsell to me. BTW - there may be an input screen on the solenoid that can be cleaned.. I seem to recall hearing something about this. It should only need cleaning if the oil has been neglected.
Old Mar 15, 2017 | 07:58 AM
  #372
Sybco's Avatar
Sybco is infamous around these parts
Goodwill?
I received an $500 Goodwill Voucher offer from PNA.
Not excited about it, although better than most have received. My past year repair list exceeds most others I would have to assume
Old Mar 15, 2017 | 08:40 AM
  #373
I guess the voucher is redeemable at any friendly local Porsche dealer for goods or services?
You did good there..
Old Mar 15, 2017 | 01:05 PM
  #374
Some guys that don't have any issues breaking free the original aluminum safety-torx, simply swap out the new steel bolts and don't even need the camshaft lock tool.
Got any links for that?
Another chap and I have been doing a bit of research - and he has gotten the aluminum tamperproof bolts out of one of his old adjusters - but the bolts are not at all a common size or shape. And I know of no availability of them from Porsche.
You might be able to source them from BMW - who used a similar adjuster from the same manufacturer, had the same problems and DID issue a service campaign to replace the bolts.
More info on your suggestion would make this thread more useful.
Old Mar 15, 2017 | 06:14 PM
  #375
texas993's Avatar
texas993 is infamous around these parts
Cofred
Can you please email me at my user name @gmail? I am about to get PP to replace mine on my '11 CTT. I'd like to,get your service advisors name. Thanks!
