Install a PCM 3.1 on Cayenne Diesel With CDR 31
)) Do not speak French)))
But seams like "not available" - means no BT feature in CDR.
Then you retrofit PCM you will be able stream music from phone via BT Aux.
Also you can use BT as Handsfree, but you need microphone - this is i called voice feature.
BTW, if you will replace steering module arm you can activate voice control feature also.
NB: Before spend money be sure you will find somebody with second gen. PIWIS tool to input all activation codes.
load and clear so first find PCM3.1 unit, do you have any opportunity?
Regarding option not activated, I'm really surprised that this car has so few option activated.
Coming form AUDI, using vagcom, was easy to activate option, is it same for Porsche.
For ex, I son't have pressure monitoring or right external mirror not goind down when car is moving back.
So I was wondering if there is existing list and codes to activzate this kind of features for Porsche, any idea?
What does it mean, do you think that it's serious offer?
Seems coming from US car.
Mickael
Anyway, I'd like to start setting the Bluetooth in my car on my CDR31.
Could you explain me step by step to what I have to do?
thanks
Main difficulty is to find the Pcm 3.1 (Cayenne) unit at a good price,
try searching on ebay. My unit is from Uk.
Still, if your car does not have Bose, you need to purchase an amplifier and cables, you have the code parts in previous posts.
already challengingg to find a PCM on the market so finding now CDR31 with BT could be also complex and long.
So is there a way to upgrade current CDR31 by ordering Original parts?
Mickael
Like 95864513402
thanks to your part number, I made a quick research on web and found this:
http://www.shopdealerparts.com/porsc.../69414655-assy
there a lot of unit, but lot of partnumber..., seems to have refurbished PCM but I not able to recognize good one, could you advice based on your experience?
there is for ex 958645136 BX and 958645136X, 200$ difference but don't know why and don't get the difference.
What would be the right part number for PCM3.1 (including Bluetooth)
Mickael
958645136BX - changer+BT 2012+, should be exchanged on 95864513602
958645136 X - same but for 2010-2011, replace on 95864513600
Parts with "X" - means you bring broken unit and get new on exchange.
always perfect, thanks you!
Does Radio control unit means CDR31 and GPS navigation system means PCM31?
knowing my case (CDR31 w/o Bluetooth) and expecting PCM3.1 (with Bluetooth) , could you tell me the part number I have to order (I would not send them any broken unit!)
Mickael
