BMC air filter
Old Jul 18, 2014 | 09:18 AM
mep1811's Avatar
mep1811 is infamous around these parts
BMC air filter
Anyone use the BMC air filter ? Their ad in the classified section for the forum is very ambitious.
Add Power, Fuel Economy and Throttle Response With a BMC Filter!
Old Jul 18, 2014 | 05:22 PM
BlazinPond's Avatar
BlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud of
My guess after limited research, is that any gain is only observed in combination with mods:
- Cat bypass pipes
- GIAC or other tune
- IPD plenum
Old Jul 18, 2014 | 05:40 PM
eliah3us's Avatar
eliah3us is infamous around these parts
Been using it forever but as part of my mod package....you won't do much for you if used by itself..
Old Jul 18, 2014 | 11:00 PM
mep1811's Avatar
BMC air filter
What kinds of mods do you make? I have a base model with a manual transmission.
Old Jul 18, 2014 | 11:06 PM
eliah3us's Avatar
There's not much you can do unless you have a turbo Cayenne; I am talking about performance gains. You could change out your exhaust for a better sound and 10-15hp gain coupled with a BMC filter. That's all I can think of.
Old Jul 19, 2014 | 01:38 AM
mep1811's Avatar
Bmc
Old Jul 19, 2014 | 06:31 PM
Aifanoo's Avatar
Aifanoo is infamous around these parts
thanks god someone open this subject , guys I have GTS, I want to use one of these air filter K&N or BMC, but I hear I need to wash them before use cause they have oil and it might cause issue, can someone please advise how to do that, like put them under water then wait until they dry ? I will use them after doing cat bypass,
Old Jul 21, 2014 | 01:43 AM
mep1811's Avatar
Those types of filters are reusable. You wash them out after a year or whatever time frame. Let the filter dry and spray an oil substance on the filter material.
http://www.knfilters.com/cleaning.htm
Old Jul 21, 2014 | 12:59 PM
Emmanuele Design's Avatar
Emmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond repute
Most customers note the improved throttle response as the most perceivable difference. In terms of the power gain, you have to be very tuned in to feel 5-10 horsepower. With that being said, at the price point, each customer I've followed up with has been very satisfied with the filter upgrade.
In terms of the upgrade on an N/A motor, your power is ultimately limited by how much air you can get into the motor. Without the aid of a power adder such as a turbocharger, it becomes even more important to free up as many restrictions along the intake tract as possible. As such, with a less restrictive filter element, you will certainly see nice benefits!
Feel free to PM me if I can answer any specific questions for you!
Old Jul 21, 2014 | 06:42 PM
Aifanoo's Avatar
Thank you guys
Old Jul 22, 2014 | 12:50 PM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
honestly its all b.s you wont notice any power gains from an air filter. I used to run K&N in all my other cars, it doesn't do anything noticeable. you can also reuse the filters, but if you apply too much oil you'll fry the maf sensors and need to replace them. i always treated the k&n's as throw aways and just bought new ones when they got dirty. but, now i just run the oem paper types in all my cars.
Old Jul 22, 2014 | 04:10 PM
Needsdecaf's Avatar
Needsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud of
This
Only useful if the OEM filter is restrictive. I ran a BMC filter on a previous vehicle and conducted manometer tests to measure pressure at several locations along the intake. Didn't amount to
Much gain.
Sounds better though.
Old Jul 22, 2014 | 04:34 PM
XLR82XS's Avatar
If concerned about oil and MAF contamination use a AEM or AFE dryflow filter. I run AEM dryflows in my E500 and they're terrific.
HIGHcard
Sep 24, 2015 08:09 PM
shifter_
Sep 8, 2015 12:07 PM
DLF
Cayenne Turbo
Sep 3, 2015 01:36 PM
