958 DIYs
The 958 sub-forum is in need of a thread with the collective experience and knowledge of DIYers. Please post Cayenne (958) DIYs in this thread
Air Filter Removal and Replacement Side Marker Removal and Replacement DRL Adapter for GTS/Turbo Bumper Conversion Porsche OEM license Plate Light Retrofit |
You can add most of the links from from sig (you already have one).
Great idea, we should have done this a long time ago ;) |
I did a little Dash Cam Installation Guide
Originally Posted by TyroneR
(Post 4295535)
glad to help, this should be useful for many =)
Installation of CTEK 56-864 Battery Charger in Cayenne 958
Posted on another forum. This is very handy when you want to charge your battery or go away for awhile. Easy on/easy off...
http://www.renntech.org/forums/tutor...n-cayenne-958/ |
Great idea! Thanks! :cool:
I have a few more in my signature. Aside from that, I also have a DIY that i am putting together for my IPD Plenum install. Coming soon... |
BlazinPond with another crowd pleaser - IPD Plenum DIY. Let's get this added to the sticky :)
https://www.6speedonline.com/forums/...stall-diy.html - Jason |
Any DIY on removing the air-intake grilles on the front bumper (left and right, two grilles on each side). My V6 model comes with body color-matched grilles which I think looks less-aggressive/sporty. I plan on plasti-dipping them black to match the front center grilles.
It feel like it should be pretty simple to remove but don't want to break anything in the process. Not quite easy to determine where the tabs are by just looking at it from the outside. I'm hoping I do not have to remove the front bumpers in order to take them out. Thanks in advance. :) |
Blackvue Front/Rear Dashcam install
Oil Reset using X-431 R tool
Reset my Cayenne 2012 Oil Change warning using the X-431 tool:
Worked for me today on my 2012 CTT and others on other posts. Plug the X431R into to OBDII port. Turn on key. Mine came with Chinese menu and instructions. Here's the way to get it into English menu. You can also access the menu by plugging micro USB cable into port on bottom and connect to power supply, then press the blue button to exit to the normal menu where you can use these instructions to set English prior to bringing out to car. Chinese is in same position as English. These are the English equivalents of the screens. First screen take the second to last item down (Tools) See below: https://cimg0.ibsrv.net/gimg/www.6sp...a7e51629ca.jpg If in Chinese, scroll down to second to last item and press green return button. https://cimg3.ibsrv.net/gimg/www.6sp...7c25aaa2ea.jpg press green return https://cimg4.ibsrv.net/gimg/www.6sp...0829ca445d.jpg select language press green return https://cimg1.ibsrv.net/gimg/www.6sp...2cb92e4d6e.jpg on third page second item down is Porsche After completion you will see a place where you set the date and choose interval. I did the reset in Chinese so I don't have the English equivalents. https://cimg2.ibsrv.net/gimg/www.6sp...0afc29f7b0.jpg reset interval? https://cimg3.ibsrv.net/gimg/www.6sp...a42542d7a5.jpg set date to go from. https://cimg5.ibsrv.net/gimg/www.6sp...0cecf8bbb2.jpg progress menu https://cimg6.ibsrv.net/gimg/www.6sp...c23329baf3.jpg porsche in chinese |
I just submited my first post.
50% complete, yet to finish. DIY - 958 PCM3.1 Video Interface and Android Module Installation Thanks |
Thank you for sharing these tasks. Save $$$. I need to replace cabin air filter. Do have a procedure how to do it?
many thannks |
