Air suspension reverting to "Normal" position
Subscribe
Mar 14, 2015 | 02:29 PM
I set my suspension to Low 1 (level 1 notch down from Normal). But it seems that on occasion, I notice that it is back to Normal level. I cant figure out what causes that (switching in/out of Sport mode or Comfort, etc).
Is this normal, or am I imagining it and bumping the lever up or something..?
Reply
Mar 14, 2015 | 04:36 PM
I've only seen this when the car is in the loading level. It raises the car back to normal when you drive off.
Reply
Mar 14, 2015 | 04:38 PM
I never use the loading level option.... I will have to keep an eye on it to see if I can correlate it to some activity...
Reply
Mar 14, 2015 | 06:54 PM
our headlight switch turns itself from auto to off all the time without any input.
Reply
Mar 14, 2015 | 08:05 PM
Quote: our headlight switch turns itself from auto to off all the time without any input.
mine does it occasionally too....
Reply
Mar 14, 2015 | 11:55 PM
Never had a problem with that, except for the noise I started to hear from the air pump? Once you select the low level, it shouldn't change, unless it is the Loading Level. At Normal level, the car goes to a lower level automatically at high speeds (140 km/h or more) and goes up to the normal height again once you reach 80 km/h or lower.
Reply
Mar 15, 2015 | 07:18 PM
My headlight switch also turned off , however I found out from a salesman that he had a customer that figured out that he was actually hitting it with his knee.
Since I have set my seat to go back when I get out it doesn't happen. I also realized i was hitting it with my knee, you don't even feel it.
Reply
Mar 18, 2015 | 02:50 PM
I was able to replicate this several times today. If I am in the low 1 position and push the sport button while at a stop, it changes my suspension setting up to Normal. Did this several times today.
Have no idea why that would be a feature. Seems if anything it would lower from Normal to Low 1 for sport...not the other way around.
Ironically, if I press sport while moving, it doesn't do it. ...maybe a bug?
Reply
Mar 18, 2015 | 03:34 PM
Quote: I was able to replicate this several times today. If I am in the low 1 position and push the sport button while at a stop, it changes my suspension setting up to Normal. Did this several times today.
Sounds like a bug to me. When the car is in Normal height, it should lower to Low 1 when sport button is pressed, regardless moving or not.
Reply
Mar 21, 2015 | 03:03 PM
Its ur knee when getting out!! I have a baby seat behind me so had to move up to make room, noticed I started hitting my knee when getting out and turning that switch in all sorts of directions!!
Reply
Subscribe
