Porsche Car Connect app
Searched and could not find much if anthing.
My 2016 e-hybrid Cayenne has the ability to monitor various functions via my iphone and an app called Porsche Car Connect.
Anyone use it?
Apparently need to bring car to dealer to 'program the car'... I registered on the Porsche website but the app asks for an activation code. I would guess this is what the dealer has to 'pair' to the app and car.
Any experience would be appreciated.
Anyone use it?
Yes, the dealer needs to activate the system for you in the car. Should have happened before you took delivery. App works fine, but a little slow in actually connecting to your car for info. Nice to be able to confirm your car is locked and see some of the statistics.
Call the dealer to see if they did the initial system activation in their shop Their is also an activation code that is text to your cell every time you install on a new device. Make sure that is not the activation you are referring too.
My dealer is clueless. He initially said (service dept) it was a $75 charge. He called back today and said sales would cover the charge for the Apple Car Play. It was a message so did not yet clairify Porsche Car Connect v. Apple Car Play. Which brings me to another question as I thought only the new 911 had that enabled thus far....
I think you summed it up when you said he was clueless.
The PCC activation should be part of the standard predelivery process. you should NOT have to pay for it. Call back and talk to the service manager or someone that knows what they are talking about. Last resort call Porsche. That is an included service that you paid for when you bought the car.
Hope to have ApplePlay some day....
Is PCC something that comes standard on all 2016s or is it an option that should be listed on the Build Sheet?
(I just leased a 2016 base Cayenne off the dealer's lot and there was no discussion of it during delivery that I can remember.)
http://www.porsche.com/usa/connect/carconnect/
This must be correct. My dealer believes if it is not listed as a line item on the window sticker it is not on the carr.
I believe PCC is only standard on the S eHybrid. Others have to add it.
@X5B4 - you have to have the optional ACC/Heating unit (forget the exact name) to use the feature in your PCC app. I just remember it was very pricey for some limited added convenience (about $1,500).
Aux heating & Cooling - PCC App
Are you saying you can control the climate system if your car is plugged in WITHOUT the option? Don't think that is the case.
PCC App while plugged in
got this from the FAQ document on the car connect site:
5.11. I have activated the departure timer with precool/heat for my Porsche E-Hybrid vehicle. Why is the charge status below 100 % at the time of departure?
If the departure timer was set for 7*a.m., for example, your vehicle's high-voltage battery will start charging at 5*a.m. The charging process is complete after 1:30*h. Over approximately the last 30*min., your vehicle is precooled/heated ready for use.
If there is an inadequate supply of electricity from the supplier, the power required for the precool/heat may be higher than the available charge current. The battery may therefore be discharged during the precool/heat process, resulting in a charge status of less than 100 %.
Timer to heat up or cool car
I found the option in the car connect app...if you click on the menu bars in the upper left, you will see an option under emobility for timers, you cn set up a single or repeating timer for vehicle heating cooling when plugged in.
