Muffler Upgrades
Old Dec 4, 2016 | 09:02 PM
SuperStar's's Avatar
SuperStar's is infamous around these parts
Muffler Upgrades
Does anyone know what the difference between the front hole closest to the rear of the vehicle? And the rear hole closest to the front of the vehicle? ( standing from rear looking at bumper) on the muffler of the Cayenne V6. I have seen some people use both or switch them around. Does one set give more power or sound than the other and why??
Old Dec 5, 2016 | 06:13 AM
spyderman33's Avatar
spyderman33 is infamous around these parts
there is at least 3 threads about this... Look it up.. Short answer is yes, there is a difference in sound.
Old Dec 5, 2016 | 01:11 PM
Well darn spyderman33... look it up??? Ive obviously looked around through the threads and could not find the answer of why and how it makes the sound different. Your answer seems like I was bothering you. Lol. Please dont reply if it is an issue to give me the answer I was looking for I dont want the short answer bro! I am new to forum so i didnt know it was discussed before.
Old Dec 6, 2016 | 05:29 AM
seabrook's Avatar
seabrook is infamous around these partsseabrook is infamous around these parts
The muffler in all Cayenne's is the same and the same with the PSE. The only thing that makes a difference on the PSE is the hole that you see plugged is connected to a valve and when you hit the sport button it opens up the valve. Also the hole that you see plugged is an internal bypass to the muffler, so it free flows. Some have had muffler shops tap into the plugged hole with a second pipe and then you have a cheap PSE. The only drawback to doing this is you will have loud exhaust all the time and some don't like that.
let us know if you get it done. I would love to engineer a package that someone could order and install themselves. I guess it would be pretty easy- the package would include quad tips (some have listed some inexpensive ones on here from China), a mating connector that connects to the muffler, compression strap that would connect the mating connector to the tip (one tip would need to be trimmed in the package probably), and a hole saw. The only problem I could see is you would have to bring it to a shop to get the mating connector welded in.
Old Dec 6, 2016 | 12:21 PM
Session's Avatar
Session is infamous around these parts
I can't speak for the V8 engines but in the V6 I only noticed a very slight increase inside.
Old Dec 6, 2016 | 01:34 PM
thank you so much for educating me on how that works!! I understand now...
Old Dec 6, 2016 | 04:47 PM
I wasnt being a dick but there was a thread directly below yours that is titled "v6 quad exhaust sound".. i see you are new to the forum so i was being nice.. you will get bashed on other forums for asking a question that has been discussed.. if you are that sensitive to a comment, the forums may not be for you. good luck.
Old Dec 6, 2016 | 05:42 PM
its all good bro! I actually did look at that thread 1st but they did not go into technical detail about what makes this happen. They just explained how they did the mod. Maybe I missed it I was not trying to read 12 months of threads. But someone broke it down for me so I understand now. I have been on many forums before I'll survive!
