sticky radio knobs
Old Dec 14, 2017 | 07:32 PM
nhirsch's Avatar
nhirsch is infamous around these partsnhirsch is infamous around these parts
sticky radio *****
sticky radio *****
removed mine using two of those metal credit cards, one on each side. they popped off but needed good force.
the 958 I have uses springs to hold them on well as shown below
cleaned up like new with alcohol. damn sticky stuff. maybe I have to wash my hands more often?
before and after pics
Name:	2017-12-14 11.19.31.jpg
ID:	517845   Click image for larger version
Name:	2017-12-14 11.27.43.jpg
Old Dec 15, 2017 | 07:15 AM
wkearney99's Avatar
5 Year Member
wkearney99 has a spectacular aura aboutwkearney99 has a spectacular aura about
Was it gunk on the ***** or is the plastic itself gumming up?
Old Dec 15, 2017 | 09:30 AM
nhirsch's Avatar
I don't know. Now they feel like regular plastic. If yours feel like it has some coating, then it's that coating that somehow morphed into stickyness. It was evenly sticky on both ***** all around so I suspect it was some coating that deteriorated. you could drag your fingernail across it and some of the stuff would remain under the fingernail and you could see where you had scraped it. They feel fine now and I'm pleased the way they cleaned up. It wasn't the plastic itself that deteriorated.
Old Dec 16, 2017 | 09:14 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Sounds like the same thing the PCM ***** did on the 955/957 series. Some dealer had a package deal on two new ones.
Old Dec 16, 2017 | 09:43 PM
nhirsch's Avatar
Yes. That's where I read to use alcohol.
https://www.6speedonline.com/forums/997/217179-sticky-pcm-radio-*****-997-a.html#PhotoSwipe1513485640983
Old Dec 17, 2017 | 07:08 AM
wkearney99's Avatar
5 Year Member
Not all plastics are the same, and some react VERY poorly to the wrong kind of cleaner being used on them.
Screens, particularly, risk being damaged using the wrong kinds of solvents. But other surfaces are likewise at risk. When it doubt, it's best to start with just plain water with a little soap like Ivory (not Dawn or other harsher surfactants). Otherwise you risk breaking down the plasticizers in the material and causing it to become gooey or eventually dry out and become brittle.
This I've learned from dealing with keeping a boat clean, the combination of harsh amounts of sunlight, exposure to salt, pollution, various sunblock lotions and dirt make for a challenge finding the right ways to clean vinyl, fiberglass, carpet, leather wood and the like. The conclusion is it's often best to use the simplest/gentlest cleaners, more often, with less vigorous action. Waiting too long and hurrying to 'cut through the grime' often leads to wrecking the material.
But I'm glad to hear you got them clean! Keep an eye on how they hold up over time and report back what, if anything, happens.
Old Dec 24, 2017 | 06:53 PM
Thinking's Avatar
Thinking is infamous around these parts
Ebay has some chrome ***** for the Porsche's, they just snap on over the OEM ***** and look pretty nice.
mshanler
Dec 28, 2019 08:49 AM
Darthvader
Nov 27, 2012 07:47 AM
boca996tt
May 6, 2012 10:17 AM
dysfunctional
Detailing
May 1, 2012 08:44 AM
pat
Jan 4, 2012 08:37 PM
