Need help upgrade xenon to full led headlights
Old May 26, 2018 | 11:45 AM
wexford911's Avatar
wexford911 is infamous around these parts
I want to upgrade my 2016 958.2 cayenne with PDLS xenon headlights to Full LED headlights.
We only have one official porsche garage in the country, when I contact them they told me it cannot be done!?!?! They said when they put my chassis number into the system it didn’t show any possible headlight upgrade, but I told them Porsche sell them as a kit with part number 958 044 900 90
I’m sure some one out there had done it??
Old May 26, 2018 | 12:50 PM
G_A's Avatar
G_A
G_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of light
tell me VIN. may be some restrictions for your local market.
i will check.
Any case, take retrofit kit,simply install and make programming with piwis. i should be ok for all cayennes.
Old May 26, 2018 | 01:18 PM
wexford911's Avatar
i will check.
PM you my vin mate.
Old May 26, 2018 | 05:51 PM
G_A's Avatar
G_A
sent answer. you can do it easy.
Old Feb 2, 2021 | 01:33 AM
CaySGordo's Avatar
CaySGordo is infamous around these parts
Is it in any way possible to upgrade the lights if my cayenne didn’t come with PDLS / cornering lights…?
Old Feb 3, 2021 | 12:55 PM
G_A's Avatar
G_A
Yes, for sure.
You need install afs unit if not present in the car and level sensors if car with steel springs.
Old Feb 3, 2021 | 03:16 PM
CaySGordo's Avatar
Yes, for sure.
Ok, so I am on air sus, afs unit is that a big job?
need electronic reprogramming?
thanks for the reply! G
Old Feb 4, 2021 | 01:49 PM
G_A's Avatar
G_A
not to big job. just wiring and coding
Old Aug 22, 2022 | 04:53 PM
Luxsan's Avatar
Luxsan is infamous around these parts
have you done it before ? You got any instructions ?
I changed the lights and the 4 dots led are working (drl) and when I put my main beam it looks like some other lights not turned on and dim.
Old Aug 23, 2022 | 12:30 AM
G_A's Avatar
G_A
I changed the lights and the 4 dots led are working.....
You get used headlights? Did you connect piwis after replacement?
Old Aug 23, 2022 | 02:20 AM
Luxsan's Avatar
yh I bought used headlights with all modules included.
i went to a coding specialist and he said piwis is not detecting the headlight modules at all.
Old Aug 30, 2022 | 02:10 PM
Luxsan's Avatar
Anyone got any updates for this retrofit ?
cadman
Nov 13, 2025 08:57 AM
lovingit
May 15, 2025 02:06 AM
Aisxos
Cayenne 958
Apr 28, 2018 05:45 PM
wexford911
Cayenne 958
10
Nov 22, 2017 08:46 AM
mikhail1
Cayenne
Jul 9, 2016 03:41 PM
