Front end facelift conversion: Cayenne 958.1 > 958.2
After completing a rear end facelift conversion project on my 2011 Cayenne (Project Thread LINK), I decided to go with the front to match.
Cayenne 958.1 (2010-2014):
Cayenne 958.2 (2015-2018):
I've seen pictures from a member from Malasia, who did it, so it is definately doable.
There are two problems with this project:
1. You need to change 8 metal parts under the hood, that support the new style hood and fenders (8 parts in total). Some cutting and welding is necessary, which makes this a MAJOR project.
2. The guy in Malasia that did the project, was unable to make the AFS feature and high beams work on his car.
A work around for the #2 would be just to use the facelifted xenon headlights vs the cool looking full LED.
I decided to start with buying the LED headlights and trying to make them work, before I order any parts.
I will also probably need a new Gateway module, and maybe also new AFS modules.
hey bro im from malaysia also im also intrested to change my old 958.1 to the new 958.2 as i see that you have see any page or picture that Malaysian successful change to new FL do u have the link of it ? (might try to contact with them ) appreciate if u can help me because i try look in google for long time didnt found it
Send me a private message or give me your email and I will send you a contact # to the person that did it.
Mind you - the high beam issiu hasn't been solved yet by anyone I know of (you will loose high beam and PDLS feature). I still haven't done the conversion because of this.
DCTMOTORSPORTS
Jan 19, 2018 05:16 AM
TT VIPER
Cayenne 955/957
22
May 9, 2014 01:34 AM
