Convert TailLights Cayenne 958.1 to 958.2
Old May 18, 2018 | 08:47 PM
  #91
apthous's Avatar
apthous is infamous around these parts
Originally Posted by Elberoth
OK, thanks. I'm affraid the AFS system may make this difficoult.
I did two similar FL projects before: on 2010 Audi S5 and 2010 Audi Q5. Both involved bi-xenon to bi-xenon swap. The swap was easy (basicly plug & play) because cars were not equipped with AFS. From what I've read, doing such a swap in AFS equipped cars is much more difficoult.
Yes indeed u need an AFS module as FL uses Private Can and 11-14 model uses Crash can signal.
Coding is needed for the conversion in order to make the headlight led lid up as well.
Old May 20, 2018 | 08:05 AM
  #92
Elberoth's Avatar
5 Year Member
Elberoth is infamous around these parts
BTW - I have managed to sell many of my leftover, pre FL parts already.
With everything sold, my parts bill should be ... $0 (yes, zero).
That would leave me with $1200 labor bill. Not bad, for such an extensive project which transformed the look of the car. If my car was in a different color than white (which has changed from pre to post lift model, forcing us to respray the tailgate and bumper from the new Flat White to the old Sand White), my labor bill would be even lower.
I can imagine doing this project for as little as $700 on a car say in black (any color that was carried over from 2010-2014 to 2015-2018 model).
Old May 23, 2018 | 07:08 AM
  #93
Elberoth's Avatar
5 Year Member
I'm decided to abandon the front FL project. This is no more a simple parts swap job, like the rear end FL. The entire front car body (under the panels) is different. To do it right, one would need to cut & weld pretty much the entire front of the car, as the apron assembly is different, due to different shape of the hood / fenders:
Old May 23, 2018 | 10:11 AM
  #94
G_A's Avatar
G_A
G_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of light
bad news! you was just few steps away...
Old May 25, 2018 | 11:38 AM
  #95
Elberoth's Avatar
5 Year Member
I have installed the new, FL steering wheel to finish the project off
Old Sep 5, 2018 | 06:41 AM
  #96
Elberoth's Avatar
5 Year Member
Help needed.
I want to instal the wide version of wheels arches, like the one pictured:
Since I have the 958.1 front and 958.2 rear right now, what wheel arches do I need ? Pre or post facelift ones ? Maybe they are interchangable ?
I have checked at Porsche and the wheel arches for the 958.1 and 958.2 have different parts #.
Old Nov 19, 2018 | 03:38 PM
  #97
LAwR's Avatar
LAwR is infamous around these parts
I keept my original wide wheels arch and they fit perfectly, also look almost identical with facelift ones.
I don't like GTS 958.1 ones.
Old Nov 19, 2018 | 08:03 PM
  #98
Jan Samy's Avatar
Jan Samy is infamous around these parts
Wiring pin
Hi there i like to do the same think can you please tell me which wires i need to re pin for the new taillights to work.please thank you.jan
Old Nov 28, 2018 | 06:49 AM
  #99
Elberoth's Avatar
5 Year Member
You are attempting to do the conversion, but didn't even care to read this thread. Why should anyone care to answer your question then ?
Old Nov 28, 2018 | 06:52 AM
  #100
Elberoth's Avatar
5 Year Member
I have put the wheel arch extensions. The car starts to look the way I wanted it to look. I may change the wheels (again) though. I may go for RS-Spider wheels in dark grey + acid green calipers.
Next project: getting the 4-point DRL in the headlights to work.
Old Nov 28, 2018 | 06:55 AM
  #101
LAwR's Avatar
Cars need "21 wheels, side gts skirts , and everything painted in white.
Also consider front bumper Gts too.
Old Nov 28, 2018 | 07:09 AM
  #102
Elberoth's Avatar
5 Year Member
I don't like the look of the rear bumper lower valance painted in white, so I will keep the lowers unpainted. I will probably go with 20" Spyder wheels, as that is one of the very few wheels that look good in 20". I don't want 21". They look cool, but that's it.
Old Nov 28, 2018 | 01:49 PM
  #103
Jan Samy's Avatar
Hi sir
I read it your post but i try to understand but i got lost on my tailight i dont have pin num 2 in tha gate tailight and also i dont know the numbers on the plugs so i have no idea which is which can you please help me also you say in your post to remove pin 5 to 10 and reconect them i dont know what to do with wires you didnt mentioned? #1and #9 for example also#6 you say swap #2with#4and then you say remove #4 and solder to#10 i really appreciate if you can help.thx.jan
Old Nov 28, 2018 | 02:37 PM
  #104
Elberoth's Avatar
5 Year Member
The #s are on the connectors:
Just follow the manual I've created:
https://www.6speedonline.com/forums/...ml#post4711917
Old Nov 28, 2018 | 03:24 PM
  #105
Jan Samy's Avatar
I see the num now
Thank you i see the num now but on the gate old connector i dont have wire#2 and on your post say connect #2 from old connector to #2 on new connector so how can i do that? Please helpthank you
https://www.6speedonline.com/forums/...ml#post4711917[/QUOTE]
