Upgrade Head Unit?
Old Feb 9, 2016 | 01:22 AM
asmvlad's Avatar
asmvlad is infamous around these parts
It s written "cut off power protection" , but in french , i send the picture, otherwise, when pcm is on, i have all the informations on the display of the instrument cluster,and the functions on the steering Wheel works fine with the pcm.
Old Feb 10, 2016 | 12:10 AM
Serg124's Avatar
Serg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond repute
no idea except broken pcm3. not rare situation.
Old Feb 10, 2016 | 01:08 AM
asmvlad's Avatar
So, you think there s nothin to do with gateway...
Old Feb 10, 2016 | 01:48 AM
Serg124's Avatar
to install new gateway is a good thing for diagnostic or coding, but this is not your case.
is pcm3 shows outside temperature, fuel cons. etc?
Old Feb 10, 2016 | 01:51 AM
asmvlad's Avatar
Yes, it shows all these informations.
Old Feb 10, 2016 | 01:54 AM
asmvlad's Avatar
Other question, when all is installed, what i have to code on the car? If it s possible to code something...
Old Feb 11, 2016 | 10:19 AM
Serg124's Avatar
vlad, you seems to be russian, no? if yes then read here http://www.drive2.ru/l/6986951/
if all information is visible then it is broken pcm for sure.
coding enables navi, bluetooth, usb. for your 2004my it all can work without coding up to month, but it will gone.
Old Oct 4, 2016 | 12:35 PM
asmvlad's Avatar
Hi Serg,
I m back with my PCM3, it was a pcm unit defect.
I found an other unit but it was mounted in a cayenne S 957 without bose amplifier, is it possible to code it on a car with bose?
How to do it?
Thanks a lot for your anwer.
Best regards
Vladimir
Old Oct 4, 2016 | 03:13 PM
Serg124's Avatar
sure, with PIWIS
orbelo
Aug 30, 2015 12:26 PM
vr6tee
Aug 29, 2015 03:52 AM
OldBoldPilot
Aug 26, 2015 01:12 PM
The Oss
Aug 24, 2015 08:19 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
