Indicator problems
Old Jan 22, 2015 | 09:32 AM
alanrferguson's Avatar
alanrferguson is infamous around these parts
Question Indicator problems
Hi ,
I only recently bought my first Porsche , a 2009 Cayenne.
The right turn front indicator , the top one , has stopped working and a warning alarm sounds with a warning ( ! ) on the dashboard.
The Porsche dealer has said that the wiring in the light unit is 'melted' and both light assemblies have to be replaced.
This seems excessive and the cost is around $3000. Anybody else heard of this and advice would be welcome . thanks , Alan
Old Jan 22, 2015 | 08:31 PM
BG305's Avatar
BG305 is infamous around these parts
Man I just had the same thing happen last week to me. I thought it was the bulb at first. I started by removing the head lamp unit and found the problem right away. It was all the wires in the harness where bare as the plastic has come off.
It's an easy fix and the dealer down here in Costa Rica had them in stock for $100 each. I replaced them along with the fuse and wala all back to normal.
Old Jan 22, 2015 | 08:34 PM
BG305's Avatar
1 more pic
Old Jan 22, 2015 | 10:20 PM
Indicator problems
BG 305 , many thanks , what did the dealer actually replace , was it the wiring harness and not the lighting cassette ?
Thanks , I will let you know how I get on
Alan
Old Jan 23, 2015 | 08:11 AM
BG305's Avatar
It's realli easy to take the lamp assembly out of the car as it is a 1 turn nut and it pops out. That pic is the wiring harness that feeds the entire lamp so if your wires where peeling like mine there is a good chance that they fused together. I would take out the lamp and check this first then check inside the lamp housing. The dealer just replace that wiring harness that feeds the entire head lamp.
Old Jan 24, 2015 | 09:42 PM
bansasn's Avatar
bansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to all
Same thing is happening to my right headlight. What is this..? The season for the turn single to go bad?
I checked my fuse, bulb and the harness. The harness has so sign of wear and tear. Anyone else know what it could be? I might as well just replace the harness. Sonnen Porsche OEM parts have it for $38.70
I'm curious...did you black out the middle bar on your front main grille? Many thanks.
Old Jan 25, 2015 | 08:56 AM
BG305's Avatar
No I cut it out when I could not find an aftermarket 1.
https://www.6speedonline.com/forums/...nt-bumper.html
Old Jan 25, 2015 | 09:00 AM
BG305's Avatar
Take the harness out and flex the wires a bit. This should show you if the insulation on the wires is failing. Is it just the front? Does it work with your hazards on?
Old Jan 25, 2015 | 12:10 PM
bansasn's Avatar
There are no frailing or cracks when flex. All signal comes on when hazard is on except the front right side bulb. Just ordered a new hardness.
Old Feb 2, 2015 | 06:45 PM
Mr. Haney's Avatar
Mr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to behold
We really got shafted with some crappy wire in the Cayenne's, it's everywhere......:-( The insulation sucks ***.
PV=nRT.
Sep 9, 2022 06:06 PM
ant_8u
Apr 10, 2016 11:42 AM
kensilver
Sep 17, 2015 04:03 PM
I-Man
Sep 17, 2015 05:31 AM
cohenfive
Sep 15, 2015 04:41 PM
