Cayenne Side Mirror LED puddle lights?
Old Jan 26, 2015 | 03:41 PM
mikhail1's Avatar
mikhail1 is infamous around these parts
Cayenne Side Mirror LED puddle lights? Anyone know where to buy just these lights from? Easy to install?
Thank you!
Old Jan 27, 2015 | 04:49 PM
dugahole55's Avatar
dugahole55 is a glorious beacon of lightdugahole55 is a glorious beacon of lightdugahole55 is a glorious beacon of lightdugahole55 is a glorious beacon of lightdugahole55 is a glorious beacon of light
Very easy once the mirror is pulled off, grab the connection wire and gently pull, T10 light will come out on a socket. Pull out and replace with a 5 chip wedge LED ES2526289 Ziza or similar. ECS Tuning has detailed instructions.
Old Jan 27, 2015 | 09:32 PM
mikhail1's Avatar
Can I buy this from ECS tuning?
Old Jan 28, 2015 | 10:57 AM
ECS Tuning - Porsche's Avatar
What year is your Cayenne mikhail1?
Old Jan 28, 2015 | 06:01 PM
mikhail1's Avatar
2011
I have a 2011 cayenne S
Old Jan 29, 2015 | 03:37 PM
We haven't tested the bulbs yet in the 958, but all indications show that they should be exactly the same. For more information about the kit, Click Here.
Old Feb 2, 2015 | 09:12 PM
mikhail1's Avatar
Installing
Is it difficult to take the mirrors off and put the bulbs in? Anyone have a DIY on doing this or any experience on how I go about it?
Old Feb 3, 2015 | 07:50 AM
Here is a thread that a customer used, to help you get a better understanding on how to do it. https://www.6speedonline.com/forums/...y-19-95-a.html
Old Feb 3, 2015 | 06:21 PM
TGED's Avatar
TGED is infamous around these parts
I changed mine to LED. It is a bit tricky but it can be done. First you need to pry off the mirror glass, and next thing is to remove the mirror motor, then you need to remove the body-color housing. At this point you can pull out the bulb socket.
Old Feb 3, 2015 | 06:23 PM
TGED's Avatar
See pic.
File Type: jpg
Old Feb 3, 2015 | 06:28 PM
TGED's Avatar
Bulb socket is pulled off.
File Type: jpg
Old Mar 13, 2018 | 02:35 PM
Elberoth's Avatar
5 Year Member
Elberoth is infamous around these parts
Guys, I need your help with pulling off the body-colored mirror housing.
I have already removed the mirror glass and the mirror motor assy.
I have removed the bolt (green) and pressed the two plastic tabs outwards (red). I applied a lot of force trying to pry it off ... but no cigar. I've stopped as I was afraid of breaking sth.
Any help would be greatly appreciated.
Old Mar 13, 2018 | 04:46 PM
Elberoth's Avatar
5 Year Member
I have found those two drawings (958.1):
From those images there should be nothing else holding the upper part of the housing, but I still can't unclip it, even though I have managed to put not one but TWO plastic wedges inside. Putting a wedge requires A LOT of force and the whole thing is flexing like crazy.
I'm affraid to apply any more force, as I feel this thing is close to breaking ​​​​
Old May 15, 2025 | 10:59 AM
mep1811's Avatar
mep1811 is infamous around these parts
Looks like too much could go wrong with changing out the bulb. I'm going to leave mine alone.
COBB Tuning
Jan 1, 2025 09:02 AM
007AMV8
Oct 19, 2015 09:55 PM
Michael_s
Sep 11, 2015 08:03 PM
ppwchiang
Aug 20, 2015 10:28 AM
