Heated seat issue
Old Feb 27, 2016 | 11:17 AM
Trivgar's Avatar
Trivgar is infamous around these parts
Heated seat issue
2006 Cayenne turbo. I've got a strange problem with my driver side heated seat. The other 3 work great. Driver side works, but only for about a minute or so and then it turns off. If I change the heat level it'll come back on, but then turns back off. Any ideas? I've poked around under the seat and everything looks normal to me.
Old Feb 29, 2016 | 07:24 PM
jdubbya's Avatar
jdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to behold
Sounds like there may be a short or a sensor that is going bad and thinks it's getting too hot maybe and shutting it down?
Here is another thread but doesn't sound like your problem exactly. Might be some ideas there though? https://www.6speedonline.com/forums/...t-working.html
Old Mar 1, 2016 | 07:56 AM
Trivgar's Avatar
Yeah I looked through that one. Mine works, just not for long. So I was leaning more towards a sensor than a bad element. I'm just not sure where to start or where the sensors are.
Old Mar 2, 2016 | 07:22 PM
jdubbya's Avatar
I haven't taken one apart but looking at the parts diagram it looks like the sensors are built into the wiring harness for the seat. You'd have to find the specific one for your car as there are a LOT of variations but here's one just as an example...http://www.autoatlanta.com/porsche-p...section=817-30 (part #6) but it's been superseded by this part though...http://www.autoatlanta.com/results.php
I would think it would be fairly well plug and play from the looks of it anyway. If you've ever done anything with the battery you've probably had the seat halfway out already. I have, it's not too bad.
Old Mar 2, 2016 | 07:25 PM
jdubbya's Avatar
Also looks like part #4 on the diagram above is the heater control unit which I suppose could be going bad. Might be a good place to start looking but not sure if you can test it to see.
Jett911
Apr 18, 2016 04:40 AM
Sherbaz
Feb 16, 2016 09:11 PM
DerekShiekhi
Ferrari
Feb 11, 2016 09:56 AM
tcbquattroporte
Maserati
Feb 5, 2016 09:59 PM
skipath
Cayenne 958
Feb 1, 2016 07:43 AM
