2008 Cayenne S DME Transmission code 1314 Problem
Old Jun 23, 2016 | 09:23 PM
Skip's Avatar
Skip is infamous around these parts
Hey guys! Got my wife an 08 Cayenne S last year (full disclosure: I wanted her to love it so I could inherit it when upgrading her to a newer model--She's put 20000 miles on it in that year, and my master plan was working so far, except:
Recently (the past 2 weeks, after my wife went out of town for 2+ weeks) I've had the transmission intermittently pause instead of shifting into higher gear...to the point I started shifting manually. I'd pull over when I could, shut the car down, wait 30 seconds, and then start it up again. Generally speaking it would behave normally afterward.
Plugged the Durametric into it: Then, a couple of fault codes: Coils (changed last week with new plugs), 0335 Crankshaft position sensor (on order today), and 1314 DME control module. The coil problem is gone, and the other faults vanished after I cleared them. It drove nice for a couple days, but started hesitating gear changes again yesterday. The 0335 and 1314 codes are back when I checked just now..
The sad thing is my wife drove it, and it basically went in "limp" mode on her. Now she doesn't trust it, and I got to figure it out so I can get her that 2012 model so I can keep this one!
Things I have done recently (the past two weeks): Oil Change. Air Filters. Spark Plugs. Coils. Safety and Emissions testing.
Could anything I have done caused the 1314 code to come up? I've read that cracked or loose piping/fittings for Emissions Control Valves, etc. could have a hand in this.
Sorry if an answer to this is buried in the archives somewhere, I just didn't see it come up...
I appreciate your assistance!
---Rob
Old Jun 24, 2016 | 08:20 AM
Skip's Avatar
Ok, so as I dig into it more, it seems that the crankshaft position sensor could be the root cause of my current issue...anyone else have thar experience? Doing a new search on that one...
Old Jul 19, 2016 | 12:41 PM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
Have you checked your transmission fluid? How many miles?
Old Aug 4, 2016 | 09:13 PM
EMC2's Avatar
EMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud of
I just replaced the Crankshaft Position Sensor on mine. DIY and info here:
http://rennlist.com/forums/porsche-c...ement-diy.html
Hope it helps.
Old Aug 11, 2016 | 04:12 PM
Skip's Avatar
Sorry for the delay in replying...been out of coms for a bit.
I ordered the Crankshaft Position Sensor from the local dealer (who said they've never seen one go bad before), replaced it, and am a very happy Cayenne owner again!
(Fact is, I'm happier...I just took over the '08 for myself, and my wife now owns a '12 Cayenne S which she loves even more!)
REDNOSEGT
Bentley
25
Feb 12, 2024 06:39 AM
Wildcat1212
Jun 17, 2017 10:06 AM
PNW
Mar 29, 2016 02:40 PM
JimTT
Mar 27, 2016 05:57 AM
