What do detailers use to get the engine bay so clean and sparkly?
Old Apr 3, 2008 | 02:17 PM
Fkim011's Avatar
Fkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant future
I have seen some miraculous turn around in some engine bays that went from gunk to sparkling new. What chemicals are used to achieve this? I have a caterpillar that needs TLC in the engine bay and the windows have built up residue that can't be removed with just the high pressure wash anymore. Any tips on removal and cleaning?
Old Apr 3, 2008 | 11:15 PM
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
here are the products we use.
P21S autowash
Boar's Hair Brush
Steady stream of water using a firehose nozzle or a pressure washer.
And any of the below to dress the engine
Adam's VRT (dressing)
Adam's In and Out (dressing)
Black Wow (dressing
Old Apr 4, 2008 | 12:52 AM
Fkim011's Avatar
Phillip, is the high pressure what gets all the grim out? like all the excess grease, and oils? Or do you guys use a degreaser for that?
Old Apr 4, 2008 | 01:13 AM
the p21s autowash get a lot of it out, a fire hose nozzle and hose should work fine.
of course the pressure washer would work better and quicker.
Old Apr 7, 2008 | 10:41 AM
MPowerM3's Avatar
Awaiting Email Confirmation
MPowerM3 is infamous around these parts
So you just open the hood, watch the electronics, and fire away?
Old Apr 7, 2008 | 10:53 AM
Old Apr 7, 2008 | 11:18 AM
rhudeboye's Avatar
rhudeboye is infamous around these parts
Originally Posted by pyiu
I cant get the video to play. In Firefox it will load but not play. So I go to IE and I cant get the page to fully load.
Old Apr 7, 2008 | 01:45 PM
cellg8's Avatar
cellg8 is infamous around these parts
i have seen ppl mentioned some cheap detailers use WD40
Old Apr 14, 2008 | 11:09 AM
Stealth 993's Avatar
Stealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond repute
I degrease first, use a dedicated brush for this. I like Griot's oil & grease remover
Then clean off dirt after with P21 TAW or Amazing roll off.
You will have to wash a dirty engine a few times, & use a stick with a MF towel to get in the hard to reach areas. Don't blast the water on the engine, just the sides & under it. Water can get into the "Hemi Head" spark plug holes & cause misfires. Older BMW's seam prone to this.
Then dry off, wax the painted stuff, & apply your fav plastic/rubber to everything else.
A good engine detail on a dirty car can take a couple of hours to do right.
This is my old DD with 90kmi on it!
Jul 29, 2019 11:13 AM
I'mAllIn
Sep 11, 2015 06:38 AM
Ferrari
Aug 24, 2015 04:35 PM
Glasig
Aug 23, 2015 03:35 PM
