CR2 Spotless - low pressured water?
Old Jun 19, 2008 | 10:22 AM
cellg8's Avatar
cellg8 is infamous around these parts
I notice whenever I use CR2 Spotless, the water pressure is pretty low (even I use the fireman hose). It's just weak comparing to when not using it at all.
Does anyone have tips on how to get the 'regular water pressure' when using this unit?
Thanks.
Old Jun 19, 2008 | 04:30 PM
Stealth 993's Avatar
Stealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond repute
The only way is to increase water pressure.
You might do better with a smaller nozzle as well.
Old Jun 19, 2008 | 04:56 PM
cellg8's Avatar
Thank you, sir!
John
Old Jun 19, 2008 | 06:06 PM
imcarnuts's Avatar
imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !
I don't want a lot of pressure as I only use it to rinse the rinse water off the car and I want it to "sheet" off. Have a plastic (so it won't scratch if it touches the car) shut off valve and no nozzle.
Old Jun 20, 2008 | 07:54 AM
MoeMistry's Avatar
Premium Sponsor
Thanks.
You should be using the nozzle that came with the unit, or any other nozzle that has a FLAT setting. The reason being that the CR should not be connected to a water source with greater than 40 psi or 2 gpm on the smaller unit or 4 gpm on the larger unit. Reason being that the numbers I just quoted are the optimum performance ratings and if you you above them, you will run the risk of spotting since the water goes through the resin bed too fast. Most home water pressure is about 70-90 psi and the nozzle can restric it to about 40 psi which is pleanty of pressure to wash a car; that's what I do everyday. I don't use a pressure washer, just the house line. Hope this helps.
Old Jun 20, 2008 | 08:02 AM
cellg8's Avatar
imc and Moe, thank you!
Moe, I don't use it with a pressure washer. I will try to dig out the nozzle that came with the unit instead of using fireman hose Thank you.
John
Old Jun 21, 2008 | 02:11 PM
bbywu's Avatar
I'd recommend a low cost electric pressure washer...
I have a pretty elaborate system for washing my 997TT.
In my area, my water is extremely mineralized...we're talking water TDS of over 550 to 600. Mostly calcium, silica, and iron...all of which will etch clear coat (don't even get me started about how I found that out.)
The spigot in garage is actually softened water...this runs to a DIC-20 deionizer, which then in turn runs to my Home Depot/Husky 1800 PSI electric pressure washer.
I use the pressure washer to presoak, foam, and rinse my car with deionized water. Most people don't bother using deionized water until the end rinse, but my water (even softened) is so bad, I don't want to take any risks.
As long as you don't hold the nozzle closer than 3-4 feet, and use the medium wide fan (lower pressure) your paint will be safe. In fact, I would argue, that in Wisconsin winter, it is safer to presoak, foam, and rinse the salt off with a pressure washer than to risk scratching the surface with any mitt.
Old Jun 21, 2008 | 02:17 PM
MoeMistry's Avatar
Premium Sponsor
Well said...you seem to have a few strikes against you but have managed to make it work. For the average DIY, I recommend using the CR all the way. Depending on how hard the water is, you can wash your car every 2 weeks and not have to change the resin for about 3-6 months.
Old Jun 21, 2008 | 02:41 PM
J_Edwards's Avatar
J_Edwards is infamous around these partsJ_Edwards is infamous around these parts
Also remember that the resin duration really depends on how poor your water quality is as well.
Yesterday we encountered a customer that hasn't replaced his resin in over 8 months, and it is still working perfectly. He washes his car weekly, so we know that he was using it a great deal. The reason he has had such a long duration with the system is because he has soft water running into the CR, which only helps to extend its lifespan.
Old Jun 21, 2008 | 03:14 PM
Maison's Avatar
Maison is infamous around these parts
I'd recommend a low cost electric pressure washer... Home Depot/Husky 1800 PSI.
How long have you had the pressure washer and how reliable is it? Also, are you saying that you don't even use a wash mitt? Touchless wash??
-Thanks!!
Old Jun 21, 2008 | 07:23 PM
MoeMistry's Avatar
Premium Sponsor
Actually, the soft water portion has no effect on the CR. The reason being that we are more concerened about the AMOUNT of impurities, not the TYPE. Soft water systems take the calcium and magnesium and exchange it for sodium and chloride, essentially salt water. The parts per million, PPM, count still is the same. DI water exchanges the Mg and Ca particles for hydrogen and hydroxide, H + OH = H2O AND reduces the PPM count. There's all sort of resin tyoe that do different things. But in a nutshell, that's the chemistry behind DI water.
Jul 29, 2019 11:13 AM
COBB Tuning
Mar 29, 2016 09:26 PM
LiquidElephant
Aug 27, 2015 06:17 PM
Gewgaw
Aug 19, 2015 11:52 PM
