Ask Moe
Old Jan 13, 2011 | 07:59 AM
  #241
MoeMistry's Avatar
Premium Sponsor
Originally Posted by pvanosta
That could work
I live in CDM and work in Newport Beach, on Birch Street just off the 73.
I don't want to impose, but if you're ever in either neighborhood, just let me know
Sounds good.
Old Jan 17, 2011 | 02:23 PM
  #242
awsum1ed's Avatar
awsum1ed is infamous around these parts
Scratched Leather Seat
Hi Moe, what do you recommend on a scratched leather seats? it's on the driver seat side of the BMW M3. i tired using the zymol leather conditioner. It still shows the line scratch. your input would be appreciated.
Old Jan 17, 2011 | 02:38 PM
  #243
MoeMistry's Avatar
Premium Sponsor
Can you post a picture Ed? My gut tells me leatherique rej oil and prestine clean combo would be the answer. But, shoot me a photo and I'll know better.
Old Feb 2, 2011 | 03:24 PM
  #244
alexstjo's Avatar
alexstjo is infamous around these parts
Hi Moe,
Need to clean and protect my dash of my 997. I don't have a leather dash wish i did! I was going to use aerospace 303 on it. What do you think?
Old Feb 2, 2011 | 04:55 PM
  #245
MoeMistry's Avatar
Premium Sponsor
Originally Posted by alexstjo
Hi Moe,
303 is an excellent product Alex. Simply spray it on a foam applicator and apply it to the vinyl or plastic surface. Then, you can wipe the panel with a soft mf cloth to even out any irregularities.
Old Feb 21, 2011 | 11:24 PM
  #246
floridaBMW's Avatar
floridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud of
Moe I have fine sratches in the paint, seen with a small led flashlight i use. Ive read that when u rub u will get some no matter what. I use 2 bucket wash, wool mit, blow dry and good MF towels to wipe product off. I fold the towels into sq and go thru 4-6 of them. Is it just the cost of doing business or am I missing a step?
Ken
Old Feb 22, 2011 | 01:21 AM
  #247
mr2guysingh's Avatar
mr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to behold
Are you talking about swirls? After you do a proper detail those scratches will go away, then with proper washing they shouldn't return for a long time
Old Feb 22, 2011 | 04:46 AM
  #248
MoeMistry's Avatar
Premium Sponsor
Ken
Great question Ken. The question is are you starting from a paint that's been properly polished and the imperfections have be eliminated? If so, then your wash routine is putting in those small scratches. The other source could be what and how you've polished. You may not have ever removed the existing swirls and scratches, and merely hid them. As you wash, you also take away the oils in a polish or wax which then reveals the imperfections that were never removed.
So:
1. What polish have you used to eliminate the swirls and scratches?
2. Done by hand or machine?
3. If done by machine, what machine and polish/pad combo?
4. Are you using a synthetic or natural wool mitt?
These are some good starting point questions...awaiting your response.
Old Feb 22, 2011 | 04:47 AM
  #249
MoeMistry's Avatar
Premium Sponsor
+1...they should never re-appear. Anything new is the result of NEW imperfections. Great input. We'll wait to hear back Ken's response to the questions above.
Old Feb 22, 2011 | 02:02 PM
  #250
millsjq's Avatar
millsjq has a spectacular aura aboutmillsjq has a spectacular aura about
I have recently purched a 09Vantage with 5K miles. It is jet black and it has more swirls and fine scratch (many that may have come from the factor) then I would have expected. To correct the paint I have at my disposal, a old rotary polisher (one rpm setting) and a Flex DA, Super Intensive polish, Power Finish, Super Finish and Final Polish and assortment of pads. I was thinking of using the rotary with SIP and a white pad, than going to Power Finish with the DA and black (gray) pad and then Final Polish/DA/Gray Pad. I am not sure what speeds to use on the DA (4?) and if this is a good progression. Suggestions?
Old Feb 22, 2011 | 02:18 PM
  #251
floridaBMW's Avatar
Ok, the car was corrected by a well known detailer in my area that is the very best, David F. The scratches are fine straight scratches, I rub front to back only. In direct sunlight they can be seen if u look, under the led flashlight they are very visible. started with an 80% correction aftr David finished with it, its a daily driver.
1. No polish, I used Pinnacle Paintwork Cleansing Lotion with a lakecountry red pad then topped it with sig II caranuba.
2. By hand, polishing pal
3. NA
4. Unsure whether its syn or natural, gonna check that tonight.
Thanks Moe,
Ken
Old Feb 22, 2011 | 09:14 PM
  #252
MoeMistry's Avatar
Premium Sponsor
On Aston paint there are several issues:
1. Microscratches
2. Swirls
3. DA sanding marks from factory
4. Compound hazing and buffer trails from factory
Using the flex will fix the following: 1,2,4
Here's your recipe:
Stage 1: Flex,SIP,purple wool pad. Start on setting 3, spread polish, and polish down on setting 5.5
Stage 2: Flex,SIP,Orange CCS Pad. Same speed and technique as above
Stage 3: Flex,Super Finish,White CCS pad. Same speed and technique as above. This step should go faster than the rest since most of the imperfections have now been eliminated.
Final Step: Wax
Take your time with stage 1...most important. This whole process should take you about 10-15 hours.
At the end, your paint will be the envy of any Aston owner within miles around. Good luck and make sure to show us your work and before/after shots.
Old Feb 22, 2011 | 09:16 PM
  #253
MoeMistry's Avatar
Premium Sponsor
3. NA
Thanks Moe,
Ken
I've heard of your detailer and he does excellent work and is well respected in the professional community. Have you shown him your finish and asked for his advice? I'm humbled you'd seek my advice, but it seems you have a very capable detailer that can give you great advice and perhaps take care of these issues.
Once these imperfections are eliminated, it should be very easy to keep up. Your technique of washing and drying is critical here. Have you purchased a CR Spotless or Airmax yet? They'll be your best friend.
Old Feb 22, 2011 | 10:28 PM
  #254
w00tPORSCHE's Avatar
w00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond repute
Moe may be u should show them those pics u shot some
time ago after your stunning new car prep on one of the Astons that u did.
Old Feb 22, 2011 | 11:07 PM
  #255
floridaBMW's Avatar
Thanks Moe, I appreciate ur humble attitude. I realize it's tough to troubleshoot without seeing the scratches ect.. I have an appointment with David in March. I just wanted to pinpoint my error, frankly I am not even gonna clay this car. I have practiced on my wifes infinity with some success. This Pcar paint is just to soft for any heavy work in my hands.
Thanks again,
Ken
1. Microscratches
2. Swirls
Here's your recipe:
Final Step: Wax
