Ask Moe
Thanks Moe and w00t. I figured it's not good - hadn't been doing it most of winter - but was hoping somehow it would be fine
. I was worried about the detergents in the soap, but not even thinking about the water spots, duh. Unfortunately I don't have the room or budget for the CR system at the moment, although it seems like the perfect solution.
It takes me 4 hours for a full exterior/interior cleaning. Just exterior is 2 hours when I have caked on mud from Tahoe and I have to gently wash and rinse the lower panels 2 or 3 times each.
. I was worried about the detergents in the soap, but not even thinking about the water spots, duh. Unfortunately I don't have the room or budget for the CR system at the moment, although it seems like the perfect solution.It takes me 4 hours for a full exterior/interior cleaning. Just exterior is 2 hours when I have caked on mud from Tahoe and I have to gently wash and rinse the lower panels 2 or 3 times each.
Sealant
Moe,
What do sealants do to protect and enhance the finish that wax won't do. If I use a sealant, will I still need to put a coat of wax on the sealant? Under average conditions, can I expect the sealant to last a year?
Thanks,
Yolev
Thanks,
Yolev
Not ALL sealants are exactly better than a carnauba wax. It all depends on which carnauba you get. If you use a sealant, then apply the sealant first. The only reason you'd apply the carnauba over a sealant is to gain more depth and reduce the gloss and shine a sealant has. This gives paint a more natural look instead of a sterile shine. IMHO, you shouldn't go over 6 month without claying, polishing, and waxing. Think about it. It's the only thing prolonging the life of your paint. It's like trying to find a toothpaste that lasts a year. Would you not brush your teeth? Same concept with waxes and your car. If a daily driver, wax every 3-6 months depending on weather conditions and wax you use. Let me know if this helps answer your question.
Mo, what kind of LC pads should I use if doing wetsanding correction with a rotary?
I know the colors I need, but which type (hydro etc..) of pad would work best with the rotary thanks!!!
200+++ posts....AWESOME!!!! Thanks for allowing me to share my knowledge with you guys. Looking forward to the nest 200
Hey Moe, I'm wondering if you can give me some advice.
We have a Black E46 3-series and the car has some paint scratches. I had them touched up with black touch-up paint but as you can guess that makes it very noticeable. We are planning on having the car painted in a year or two once I'm done school and it's paid off but I'd like to get a nice wax on it and bring out the pat.
I've rear some sites where you can lightly sand down the touch up paint to match it with the oem paint and then wax it.
Have you done anything like this before? I know this may be a bit ghetto but we are still paying for the car and I'm in school so repainting the whole car is not possible at this moment.
Also, our front brakes release a lot of brake dust and the 17" M rims get filthy up front. We can clean them good but they only last about 3-4 days before they really are dirty.
Are there any products that can make the rims cleaner and keep them cleaner longer? Some kind of a rim wax to prevent the brake dust from building up and staying on.
Thank you Moe for any advice you can provide us.
bart
bart
bart
bart
Unless you're a pro, I wouldn't wetsand anything. The best you can do is touch up chips slightly, and polish the paint to reduce the severity of the scratches.
When you're ready, just repaint and do it right. You could also send it to a body shop and have them compound and polish the paint...that will help tremendously. Just make sure the shop you use is reputable and knows YOUR car well.
As for brake dust, rejex is a great option. It's a polymer sealant and will do a great job of repelling most of the dust. Then clean routinely with P21S Wheel Cleaner and your wheels should look great.
Did this help?
We use purple for most compounding.
Sorry for the delayed response...the purple should be just fine.
I just got off the phone with Moe for the first time and I have to say he's a great guy to talk to in person. He's down to earth and gave some solid advice. I'm looking forward to receiving some Menzerna Powerlock (I'll post some pics of my car after I have time to apply this stuff!).
Probably should have asked this question on the phone, but I notice my car tends to attract a lot of dust in the back bumper from what I think is static electricity when I wax or wipe it down with a MF towel. Two of my cars are Ivory Pearl so that dust starts to show within a day or two after I clean it. Is there some way of reducing or preventing that from happening?
