Remove spotting from clearcoat and clear bra
Old Apr 8, 2012 | 10:54 AM
llngoc's Avatar
llngoc is infamous around these parts
Does anyone know how I can remove spotting from the paint surface and clear bra? I have tried the crystalline clear bra treatment from Premier and also used Meguiar's polish on the paint surface and none were working. The spotting was due to previous washes from the CR Spotless which has algae growth.
Any help? If it makes a difference, my car is a Basalt Black Porsche.
Old Apr 8, 2012 | 11:59 AM
djantlive's Avatar
so you have some stains? i doubt it'll come off if the stain has been there for a while.
Old Apr 8, 2012 | 09:40 PM
drsullivan's Avatar
drsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant future
Chemical Guys Water Spot Remover
http://www.detailedimage.com/Chemica...P194/16-oz-S1/
CSR
https://4311csr.infusionsoft.com/app...?productId=158
The above 2 are for clear coated surfaces. I'd try these for the clear bra:
Dodo Juice Lime Prime
http://www.detailedimage.com/Dodo-Ju...247/250-ml-S1/
Chemical Guy Black Light
http://www.detailedimage.com/Chemica...P529/16-oz-S1/
Old Apr 9, 2012 | 03:58 AM
TOGWT's Avatar
TOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to behold
Have you tried a chemical paint cleaner?
“Removing Water (Spots) Marks” - http://www.autopia.org/forum/guide-detailing/136608-removing-water-spots-marks.html#post1448627
Old Apr 9, 2012 | 08:28 AM
llngoc's Avatar
According to this thread, detailing clay (clay bar) should also work?
Old Apr 9, 2012 | 02:09 PM
koop's Avatar
koop has a spectacular aura aboutkoop has a spectacular aura about
Also will depend on the make of the clearbra. Some brands have a clearcoat and others do not.
Old Apr 9, 2012 | 07:27 PM
ptmobile's Avatar
ptmobile is a glorious beacon of lightptmobile is a glorious beacon of lightptmobile is a glorious beacon of lightptmobile is a glorious beacon of lightptmobile is a glorious beacon of light
Sometimes film will actually burn in spots if water drops sit on it and is left out in the sun. The water droplet will act like a magnifying glass causing the film to burn in. If thats the case there is nothing you can do to get rid of it. Pictures are worth a thousand words... and it would help a lot if you would post some.
Old Apr 11, 2012 | 06:14 PM
Jagwrjack's Avatar
Jagwrjack is infamous around these parts
Bought a new white Cayman S in 2006 that had water marks that were baked in, probably from just sitting on the dealers lot. Tried everything short of wet sanding the car. Never did remove them.
Old Apr 12, 2012 | 07:23 AM
llngoc's Avatar
Not sure if this is a saving grace or something I should be ashame of.
My car has barely 1900 miles after a year and the total time it has exposed to the winter sun after I washed it and have this spotting issue is probably less than 1 hour. Will it help to lessen the chance of baked-in?
Old Apr 14, 2012 | 02:26 AM
Premier Films's Avatar
Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !
Bring it in the original clear bra installer to have him assess it as he would have the proper solution. As others have mentioned, it is dependent on film applied, which is why its important to speak with your original installer for a solution. Good luck.
Premier Protective Films
ClearGuard Alpha PPF, Spectra PhotoSync Nano IR & CeraLuxe IRD Tint, Coatings
www.premiermobilegroup.com
Sharing our Passion on Youtube: https://urlgeni.us/youtube/Premier
Facebook: https://urlgeni.us/facebook/Premier
42630 Christy St, Fremont, CA. 510-623-1308 sales@premiermobilegroup.com
Old Jun 20, 2012 | 08:57 PM
gasongasoff's Avatar
gasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond repute
I have some water spots on my Premier clear bra. Any tips on how to remove them?
Old Sep 23, 2012 | 08:21 AM
bcgt3's Avatar
bcgt3 is infamous around these parts
Purchased my car CPO and came with the clear bra. Dealer didn't know the manufacture of bra. Its stained in a couple areas. Tried clay bar, alcohol & goof off. Any other suggestions or is it time to replace it?
Old Sep 23, 2012 | 09:47 AM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
This is generally no a job for a non professional unless it is a small area. I would think a water spot remover like chemical guys and a polish via da. Possible a 1 or 2 step process
twnj
Apr 29, 2016 05:18 AM
alevine
Nov 4, 2015 10:05 AM
Michael_s
Sep 11, 2015 08:03 PM
Glasig
Aug 23, 2015 03:35 PM
