Paul Millers' Carrera Gt Ouch!!!
Old Oct 1, 2007 | 08:06 PM
  #31
Auctung's Avatar
Auctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud of
that makes me wanna cry
Old Oct 1, 2007 | 09:56 PM
  #32
MPD47's Avatar
Only 5SPEED
MPD47 is infamous around these partsMPD47 is infamous around these parts
Funny, Wegmans truck in the background. I wonder if that car is local to me.
Old Oct 1, 2007 | 10:09 PM
  #33
jstrat85's Avatar
jstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to all
lol! dam that sucks!
Old Oct 1, 2007 | 11:21 PM
  #34
lvrs's Avatar
lvrs is infamous around these parts
That sucks.
Old Oct 2, 2007 | 12:25 AM
  #35
alkyoneus's Avatar
alkyoneus has a spectacular aura aboutalkyoneus has a spectacular aura aboutalkyoneus has a spectacular aura about
ouchhhhh!!
Old Oct 2, 2007 | 08:48 AM
  #36
heavychevy's Avatar
LOL, I had my ramps lift and come off my trailer recently when unloading at Barber, the front tires were somehow holding on to the trailer while barely touching it, the front fascia was actually touching.
I had to borrow someones ramps and prop them under mine for support and drive down, it was pretty embarrasing.
Old Oct 2, 2007 | 08:57 AM
  #37
WOODTSTER's Avatar
I am speechless...wood ramps for a CGT???
Old Oct 2, 2007 | 09:44 PM
  #38
porschenut911's Avatar
porschenut911 is infamous around these parts
Heartbreaking!
Old Oct 2, 2007 | 09:47 PM
  #39
Red996's Avatar
Red996 is infamous around these parts
thats sucks ouch its hurt my heart
Old Oct 3, 2007 | 08:21 PM
  #40
nyc123's Avatar
nyc123 is a jewel in the roughnyc123 is a jewel in the roughnyc123 is a jewel in the rough
cgt
Is that the car of Paul Miller as in owner of Paul Miller Porsche in NJ
Old Oct 3, 2007 | 08:58 PM
  #41
Scuderia-f430's Avatar
Scuderia-f430 is infamous around these parts
Damm it sounds like a lot of money.
Old Oct 3, 2007 | 09:33 PM
  #42
Josh's Avatar
Josh is a jewel in the roughJosh is a jewel in the roughJosh is a jewel in the roughJosh is a jewel in the rough
Ouch. That is bad. It is amazing how careless people can be.
While that diffuser might cost $10k, if it hit the ground hard enough to damage that carbon fiber frame, you can add another zero to that along with a cargo flight back to Leipzig.
Old Oct 3, 2007 | 11:23 PM
  #43
arcticsilver997's Avatar
arcticsilver997 is infamous around these parts
How do you use the handbrake to prevent this from happening? Sorry if this is a stupid question.
Old Oct 3, 2007 | 11:41 PM
  #44
ZAMIRZ's Avatar
ZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud of
It allows the driver to "load-up" the drivetrain and suspension using the torque of the motor, so instead of a sudden lurch when lifting off the clutch, you get a bit of a controlled creep. You basically use the e-brake to control forward movement while keeping your foot practically steady on the clutch and throttle. However, it's very easy to burn the clutch this way, you need to make sure that if you are restricting the car from moving forward with the e-brake, you put the clutch in and not let it drag.
From what I've seen, on a Carrera GT it takes some proficiency due to the grabby nature of the carbon clutch.
Regardless, in this instance, I believe they should've used a tow-strap. Somebody had a big lapse of judgment.
30vQuattro
Jan 28, 2016 06:41 AM
DBB
Jan 7, 2016 09:32 AM
Christophosphorus
Sep 14, 2015 06:45 AM
30vQuattro
Sep 12, 2015 11:14 PM
JCD911S
Sep 12, 2015 09:20 PM
