Weight of GT3 RS Wheels
Old Jan 27, 2008 | 07:06 PM
il nino's Avatar
il nino is infamous around these partsil nino is infamous around these parts
Does anyone know the weight of the OEM RS wheels?
Old Jan 27, 2008 | 08:15 PM
Max Power's Avatar
Max Power is infamous around these parts
someone once posted:
Front Wheel 24lbs 5oz
Rear Wheel 30lbs 13oz
not sure of source or accuracy
Old Jan 28, 2008 | 08:11 AM
GT3Ranger's Avatar
GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !
They are actually about one pound more than stated in the above post;
fronts:>26 lbs
Rears:>31 lbs.
Old Jan 28, 2008 | 03:11 PM
Mercedes Benz's Avatar
Mercedes Benz is infamous around these partsMercedes Benz is infamous around these parts
There are many threads about this already. Bottom line is they are just cast alloy wheels. So they are heavy. Go with a nice lightweight forged wheel.
Old Jan 28, 2008 | 04:31 PM
steve@digitalho's Avatar
steve@digitalho is infamous around these parts
Hre Cup
Try these 18" HRE Cup wheels which will shave 30 pounds of unsprung weight.
The gain on braking is incredible ! Of course it helps acceleration also but the braking is instantly noticeable. Makes the car feel lighter, more responsive, better feel of the tires. Steve
Old Jan 28, 2008 | 04:48 PM
greygt3's Avatar
greygt3 is a name known to allgreygt3 is a name known to allgreygt3 is a name known to allgreygt3 is a name known to allgreygt3 is a name known to allgreygt3 is a name known to all
Hre Cup
Is this a new wheel from HRE? I have never seen these, they look great. Are they any lighter than their C series wheels?
Old Jan 28, 2008 | 04:57 PM
The CUP wheel was designed for Porsche GT-3 Cup Cars. It's the lightest wheel they make. It was adapted for the GT-3 RS and is available through HRE. Ask for Guy, East coast sales. He has all the spec's and details. This is a rare wheel built on a custom order basis. Super strong and light, only in 18". You will lose a good part of the advantage with 19" anyway. I had their C-20's in 19" which are slighty heavier and I noticed the difference right away. Forget the stock wheels, I would never run them after using these wheels. I'm running 315's in the rear now in Corsa's. Helped gearing due to lower profile. Steve
Old Jan 28, 2008 | 05:00 PM
yeah the Cup wheels are the lightest they make. Weren't they made for GMG? Anyway, don't forget the C20 series was replaced by the C90 series which is even lighter and stronger then the C20s.
Old Jan 28, 2008 | 05:19 PM
HREMarc's Avatar
HREMarc is infamous around these parts
We used the technology from the cup wheel to make the C90 series. The C93 is lighter than the cup wheel.
Old Jan 28, 2008 | 05:22 PM
Marc, when will the C90 series be added to the website? i saw them at SEMA right when i had a set of C20s on order!
Old Jan 28, 2008 | 07:10 PM
toadinlaw's Avatar
toadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud of
What is the pro/con of the forged vs. 3piece construction.
Old Jan 28, 2008 | 08:16 PM
HRE C-90's
I have a set of C-90's on order waiting for inner front rim's. They're for my CLK-63 Black. That was my GT-3 RS in the HRE Booth at SEMA along with my CLK-63 Black. I sure like the 18" wheels over the 19's on the RS. The trend is bigger sizes for looks but performance is compromised. We walk a fine line on that point. My braking was so much better on 18" wheels. Easier to fit slicks for track events also. C-90's will be out as soon as all the 30 hole rim's arrive. It's an all new design with fewer bolts. HRE just keeps making improvements and more choices. They have a good design team, there always pushing the envelope in performance and strength. It's what I wanted them to do 8 years ago. No question they are cutting edge now ! Wheel selection is so important on a light car like the RS. Tires are another issue. They have varying weights between brands and sizes. Light tires like Michelin Cup's help. Steve
Old Jan 28, 2008 | 08:27 PM
3 Piece V Forged
3 piece give you more rim size options.
Easier to repair bent rims. This is especially true with ultra low profile tires of today and road hazards. They are very light and strong but racing is hard on wheels. That's why race teams use them most of the time. Those are some big differences.
Old Jan 28, 2008 | 09:24 PM
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
HRE Cup wheels clear CCB in 18"? wow
Old Jan 29, 2008 | 12:19 AM
Well, all the good 3pc wheels are all forged anyway. I can't come up with many great reason a 3pc wheels are better then 1 peice besides like someone said, they can be fixed easier if you damage one. I just like the way they look better.
