GT2 alignment settings?
Old Jun 30, 2004 | 10:40 AM
SteveH's Avatar
SteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud of
What alignment settings have you guys had luck with on the GT2? I'd like something for all around use (street, track, auto-x). Obviously i realize that no one alignment will be perfect for all three but something that will be pretty good for any scenario.
-Steve
Old Jun 30, 2004 | 08:58 PM
Guy's Avatar
Guy
Guy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant future
I have stock alignment on mine and it's OK for street and track.
If I tracked it more I'd probably get a little more front negative camber to reduce low speed understeer. Prblem with big neg camber is the wear rate on the street, especially if tires are assymetric ie cannot be switched left to right when part worn
Old Jun 30, 2004 | 09:36 PM
SteveH's Avatar
tire wear is not a big issue. i'm not going to compromise performance of a $200k car for $1000 extra of tires a year.
-Steve
Old Jun 30, 2004 | 10:09 PM
Guy's Avatar
Guy
In that case go for 3.5 degrees of negative camber front and back and run Cups or Corsas....................
You'll get fab cornering on circuits, but very nervous handing on the road and less traction under breaking and acceleration.
I only do 2 track days a year hence why mine's set at under 2 degrees. I can also afford as many tyres as I want..........
Old Jun 30, 2004 | 10:29 PM
SteveH's Avatar
that's a problem....
that's why i prefaced everything by saying it needs to be good on the track AND the street. i guess the answer is that the stock alignment is pretty good and balanced?
Old Jun 30, 2004 | 10:43 PM
Guy's Avatar
Guy
Yep.
I'm probably more street-biased than you are, so I'm happy with stock.
You might benefit from a slight bit of extra negative camber, if you do more track use.
The GT2 is well set-up as stock and also US cars have the same settings as ROW, unlike the 'off-road-style' Turbos in the US, which have higher ride height and also less camber.
Old Jun 30, 2004 | 11:52 PM
Code Red's Avatar
Code Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to behold
Try -2 all the way around with Corsas. It works great.
Old Jul 1, 2004 | 12:16 AM
Hamann7's Avatar
Porsche Fiend
Hamann7 is infamous around these partsHamann7 is infamous around these parts
Actually, some hardcore guys run -2.5 deg with Corsas or Cups, the difference in grip is quite substantial.
If you can afford to buy as money tires as you want, make the extra effort to get your car aligned for the track and then realigned for the street.
Tom and Arling's shop in West LA is the best aliignment place with the best equipment, period.
Old Jul 1, 2004 | 05:33 AM
watt's Avatar
watt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to behold
Lucent is excellent and cost effective - i had tom check my 97 TT before the pony express 130 and it was way out after only 2 months... so why not reset for the track if you fancy yourself a hotshoe. personally, i had plenty of fun with stock settings on my gt2's
the other issue is your sway bar settings -- some hot drivers can use stiff settings on the track and gain some track performance, but you lose traction in bumps out in the real world. Tom convicned me to soften my bars below stock and the car improved in the bumps of my daily drive.
and going to lighter wheels will improve your GT2 markedly. search for our previous commnets on alll the above
Jul 29, 2019 11:13 AM
The Oss
Aug 24, 2015 08:19 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 18, 2015 03:41 PM
